Sponsored by: Real Truck
button next to
Old Jun 14, 2008 | 05:49 AM
rickkk's Avatar
rickkk
button next to
Hi all, just bought an 04 f350 SD and the owners man does not indicate what the button next to the 4X switch is,I am guessing it is to turn on/off the pass side air bag?? Thanks all rickk
Old Jun 14, 2008 | 06:03 AM
cartmanea's Avatar
cartmanea
The passenger airbag switch uses the ignition key. You may be referring to the backup sensor silencer switch, if your truck has the backup sensors. Maybe describe the switch?
Old Jun 14, 2008 | 12:48 PM
aldridgec's Avatar
aldridgec
Old Jun 14, 2008 | 01:57 PM
rocdril's Avatar
rocdril
LMAO- when i bought my truck I could not figure what that button was, but was too stuburn? to ask. I looked all through my manual and couldnt find an answer. Finally figured it out on my own. But you have to push it every time you put it in reverse. ( on mine anyways)
Old Jun 14, 2008 | 02:39 PM
cartmanea's Avatar
cartmanea
You shouldn't have to push it every time you put it in reverse. It silences the reverse sensor beeper if you are backing up with the tailgate down or for some other reason don't want it beeping at you. If yours is beeping all the time you could have a bad proximity sensor or a wiring problem.
Old Jun 14, 2008 | 09:21 PM
jeffdoerr's Avatar
jeffdoerr
I had the dealer turn mine off. I usually have a trailer behind me and the sensor was very annoying.
Old Jun 15, 2008 | 04:03 AM
aldridgec's Avatar
aldridgec
Actually on the early years you do. It was very annoying if backing a trailer or something to have to hit the button every time you put it in reverse. I don't know if it changed on later years or not. I hope so.
Old Jun 15, 2008 | 12:56 PM
cartmanea's Avatar
cartmanea
I have an '03 and it only goes off when my tailgate is down or I'm close to something. You made it sound like yours automatically goes off when you put it in reverse, even if nothing is in the way, is this not true?
Old Jun 15, 2008 | 02:02 PM
aldridgec's Avatar
aldridgec
OH, no. I see what you mean. Yeah, if something is causing it to beep like a trailer or the tailgate, you have to silence it. I just found it annoying that you couldn't turn it off. IF you have to manuver something, going from forward and reverse a few times, you had to push the button every time you put it back into reverse.
Old Jun 15, 2008 | 02:36 PM
Green Ford's Avatar
Green Ford
My brother had to disco his too. He always has a trailer behind him and it was driving him crazy too.
Old Jun 15, 2008 | 03:08 PM
cartmanea's Avatar
cartmanea
Yeah, there should be an enable/disable switch instead of it resetting every time it goes in reverse.
