Sponsored by: Real Truck
Air Bag Light Blinking Then Solid
Old Jun 12, 2008 | 05:37 PM
Reidicus's Avatar
Reidicus
Anyone know if this can be fixed fairly easily? The air bag light flashes 4 times then stays solid. Been like this for about a month.
Old Jun 12, 2008 | 10:44 PM
cartmanea's Avatar
cartmanea
It should flash a two number code, like 2-5. It should flash this code 2-3 times then go solid. Take a look again and let us know what it says.
Old Jul 4, 2008 | 12:40 AM
Reidicus's Avatar
Reidicus
I took a look at what it was flashing. The first time I checked it was flashing 4 times than 5. Did that i think about 5 times. Than today when I was looking at it, it would flash 3 than 4 times. Then go solid after 5 sequences. Ill check tomorrow to confirm.
Old Jul 4, 2008 | 01:24 PM
redford's Avatar
redford
FTE Leadership Emeritus
Here's a list of the codes:
12 Low Battery Voltage
13 Air Bag Circuit - Shorted to Ground
14 Primary Crash Sensor - Shorted to Ground
21 Safing Sensor - Not Mounted to Vehicle Properly
22 Safing Sensor Output Circuit - Shorted to Battery Voltage
23 Safing Sensor Input Feed/Return Circuit - Open
24 Safing Sensor Output Feed/Return Circuit - Open
32 Driver-Side Air Bag Circuit - High Resistance or Open
33 Passenger-Side Air Bag Circuit - High Resistance or Open
34 Driver-Side Air Bag Circuit - Low Resistance or Shorted
35 Passenger-Side Air Bag Circuit - Low Resistance or Shorted
41 Primary Crash Sensor #1 Feed/Return Circuit - Open
42 Primary Crash Sensor #2 Feed/Return Circuit - Open
44 Primary Crash Sensor #1 - Not Mounted to Vehicle Properly
45 Primary Crash Sensor #2 - Not Mounted to Vehicle Properly
51 Diagnostic Monitor Internal Thermal Fuse - Open Due to Intermittent Short to Ground
52 Backup Power Supply - Voltage Boost Fault
53 Primary Crash Sensor Circuits - Resistance to Ground, or Internal Diagnostic Monitor Fault
Rapid Continuous Flashing of AIR BAG Readiness Lamp - All Primary Crash Sensors Disconnected
Old Sep 17, 2008 | 07:09 PM
WickedSharp's Avatar
WickedSharp
Mine is flashing code 27
It flashes 2 times, then 7 times.
Any ideas?
Old Sep 17, 2008 | 07:59 PM
dadsgreenpsd's Avatar
dadsgreenpsd
I believe that is telling you that the passenger airbag "off" indicator bulb is not functioning.
Old Sep 17, 2008 | 08:02 PM
WickedSharp
You're right! I just noticed that the "passenger off" light was not lit up.
Hmmmm
THANKS!
Old Sep 17, 2008 | 08:27 PM
cartmanea's Avatar
cartmanea
I think a bad light bulb/led causes this. Ford will charge you a butt load for the part, but you can replace the LED yourself for a few bucks, Radio Shack probably has what you need.
Old Sep 18, 2008 | 06:31 AM
dadsgreenpsd
Make sure that if you get an LED, that it has a resistor built it. Otherwise, the truck will still see it as "burned out".
Now, back to our regularly scheduled error codes.....
