Weiand Intake Vs Eldebrock Intake??
Old Jun 12, 2008 | 12:15 PM
OldBlue68's Avatar
OldBlue68
Hello i have a 400 thats in my street rod, i am looking into upping the heads and cam to a more high performance one. I currently have eldebrocks cam, intake, holley carb bored 30 over. should i switch out intake manifold to the weiand or is that eldebrock fine? ive heard that the eldebrock performer is not the best intake to use due to it not flowing as good at high rpm. Thanks
Old Jun 12, 2008 | 10:39 PM
Eagle460's Avatar
Eagle460
I would go for the Weiland intake, personally I think a lot of edelbrocks stuff is not as good as they say it is, a lot of what your paying for is the name in most cases.
IMO anyway...
Old Jun 12, 2008 | 11:07 PM
fleetbob1's Avatar
fleetbob1
The Edelbrock is fine for a 400M
first of all the 400M is not a high rpm motor, 6500 tops. It stops making power above that, and you are asking for trouble in your engine.
the Weiand is for better flow at higher RPMS
or above 600HP
stay with the Edelbrock !
Old Jun 13, 2008 | 12:16 PM
Winder's Avatar
Winder
I have to ask what makes a 400 NOT a high rpm motor? It is a 351C with a 1" taller deck height. You can build the 400 to do anything the 351C can and then some. And there is no such thing as a 400M.
If you are really looking to turn it then install a 351C intake (with adapters).
Old Jun 13, 2008 | 12:34 PM
hollenjoe's Avatar
hollenjoe
Yes you can build a high reving 400, the thing is that they have alot more friction to work with due to the 4" stroke so it would take big port heads even bigger that the 4v (iv simulated them and cant seem to pass the the power band over the 6.5k limit) and a blower to fill in the ports with good velocity, also the standard connecting rods are said to be good enogh to rev up to 7.5k (dont know how true this is), anyways In my built im aming for 5k mid range maybe later ill get some 4v heads and aim for 6.5k who knows.... people use this engine for its stroke due to torque so almost nobody with a 400 is willing to go high in the rpms..they just dont need it, my opinion.... yes use the weiand for better mid range if your aim is higher rpm use a singleplane...
Old Jun 13, 2008 | 12:52 PM
Winder's Avatar
Winder
The guys running 460s stroked past 500 cubic inches do not seem to have a problem and their heads are not as big as 4V Cleveland heads. There is no issue with friction or filling the cylider. There is not a whole hell of a lot of difference between the edelbrock and Weiland intakes. If you already have the e-brock then run it.
Check out Engine Masters Challenge if you want some build ideas and see what the motors are capable of.
Check out the TMeyer sponsor link at the top of the page for some dyno results for the 400 engine project.
Old Jun 24, 2008 | 09:56 AM
werneil's Avatar
werneil
hi old blue, all components depending on type, style, duration, c.f.m. etc. etc. mean
more to your motor than "brand" . yes some are better than others but most times it is
compatability of parts rather than "brand name"
Old Jun 24, 2008 | 01:24 PM
slowsuki's Avatar
slowsuki
for what it is worth just changed my intake from sp2p edelbrock to weiand 8010, and did not see much change. lost a little on bottem and gained a little on top, but i only turn 4500 rpms. if you are going to turn 5000+ the weiand is the way to go, but i could not think there would be much gain if you have the performer edelbrock.
Old Jun 25, 2008 | 09:37 AM
beartracks's Avatar
beartracks
As for the 460, it's not really known as a high winder either. Have you ever actually seen the heads on those things? Looks like you could drop a baseball down the ports.
Old Jun 25, 2008 | 07:03 PM
danlee's Avatar
danlee
Stock 460 exhaust ports flow like sludge in winter. I don't think a 460 will rev past 5K without aftermarket heads or serious porting.
The Weiand #8010 is my first choice in a manifold for a 2V headed 400, but I wouldn't swap out an Edelbrock Performer. There is not that much difference.
Old Jun 26, 2008 | 07:59 AM
EFM's Avatar
EFM
I've been thinking of an air-gap for my cleveland, but $345 seems like too much.
Does anyone think it's worth it.
Old Jun 26, 2008 | 02:26 PM
danlee's Avatar
danlee
The Edelbrock RPM Air Gap Manifold is an excellent manifold. I wish there was one available for the 400. There are many other very good manifolds available for a 351C, and $345.00 is pretty steep.
Old Jun 26, 2008 | 04:00 PM
mark a.'s Avatar
mark a.
Weiand seems to be the one of choice but for the street it probably doesn't make any difference. What I can tell you is I bought a new Weiand ran it for more than 5 years and then sold it on ebay for pretty much what I payed for it.
Old Jul 2, 2008 | 11:01 PM
80broncoman's Avatar
80broncoman
The stock 2bbl heads have decent sized valves and ports and can be made to flow plenty of air. I'm building a 400 for a Mud/trail truck and have done some simple home porting and have bought some stainless valves with the undercut stems that should aslo help.
If money is no problem then by all means skip the effort and buy some of the CHI alum heads and intake.
If you to up the performance, raise the compression, raise the cam duration, and air flow. Just make sure the parts are all supposed to work at the same rpm range.
bullshot318
1978 - 1996 Big Bronco
Feb 8, 2015 08:04 AM
Haydendh
Oct 12, 2014 08:25 PM
DEWITTAUTOTECH
Jan 4, 2014 12:45 AM
muscletruck
13
Jun 6, 2010 04:30 PM
barca_texas
Feb 18, 2005 12:14 AM
