Sending Unit Gasket
Old Jun 12, 2008 | 11:32 AM
BlueovalFE's Avatar
BlueovalFE
Sending Unit Gasket
When I put the new Painless wiring harness on recently ('69 F-100) it only has a hot wire to the sending unit. If I use the gasket, it prevents the thing from being grounded. The PO had used some kind of sealer around the sending unit to prevent gas leaking, I'm guessing. Is this an acceptable way to do it?
Old Jun 12, 2008 | 11:38 AM
thesprocket26's Avatar
thesprocket26
I think the stud in the middle on the sender is your hot connection point and you have to have (or make) a wire that goes from the sender to the gas tank mounting bolt or cab wall. I want to say there should be a tab on the sender for a connector to slip onto.
Old Jun 12, 2008 | 02:18 PM
qman's Avatar
qman
sprocket is right. There should be a tab on the sending unit to attach the ground wire to.
Old Jun 12, 2008 | 02:31 PM
BlueovalFE's Avatar
BlueovalFE
Yep, there is. Sounds workable. Thanks, guys.
newblder
15
Jul 1, 2017 04:18 PM
rdpickett406
1978 - 1996 Big Bronco
Jan 23, 2015 08:29 PM
danielescoboza
May 4, 2013 06:19 PM
bigf350sd
1947 and Older Ford Trucks
13
Jun 19, 2012 05:36 PM
mlcarey1959
1983 - 2012 Ranger & B-Series
16
Jun 4, 2004 08:50 PM
