gas tank sending unit
Old May 3, 2013 | 09:51 PM
danielescoboza's Avatar
danielescoboza
the sending unit on my 76 f150 is not working reads empty, new sending unit good ground, new gauge and still dont work...I pull the sending unit out and wired and play whit the flaoter and the gauge work just fine soon it i drop the sending unit in to the thank quit working...HELP
Old May 3, 2013 | 10:35 PM
jajones1988's Avatar
jajones1988
Only thing I can think of is if there is a hole in the float so it would just sink in the fuel. But im no expert, this is just my 2 cents
Old May 3, 2013 | 11:58 PM
crownver's Avatar
crownver
Maybe you're out of fuel! Seriously, it could be that the float arm is too short. If you shake the float when you pull it out you should be able to hear gas in it if it's leaking. Make sure the sending unit is grounded when installed.
Old May 4, 2013 | 01:29 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The float is made from two pieces of copper soldered together. Solder breaks down, gas seeps in, float settles to the bottom of the tank.
Carpenter sells a one piece brass float for about 5 bucks that won't allow gas to seep in.
Float same: 1957/79 Passenger Cars/Trucks, 1961/79 Econolines & 1966/79 Bronco's.
Old May 4, 2013 | 06:19 PM
danielescoboza
I'm know i got some gas in my thank went i pull de sending unit out the first time i have gas spill all over my drive way so a least 1/4 thank in it, I'm realy confuse now...sending unit out put a ground cable directly from the thank to the fuel line in the sending unit and does the same thing automatic reads empty
82fordowner
Sep 2, 2013 07:37 PM
ManfredVonRichtofen
1978 - 1996 Big Bronco
25
Feb 14, 2013 05:51 PM
fordnurse
May 8, 2011 08:12 PM
mater73
Dec 22, 2010 10:49 AM
rlay302
Nov 3, 2004 01:17 PM
