Auto trans identification
Old Jun 11, 2008 | 05:01 PM
02xlt3.0's Avatar
02xlt3.0
OK, noob question; how do you know which transmission you have? (Other than the obvious "automatic" of course; even I can get that one).
Old Jun 11, 2008 | 05:18 PM
ranger88a's Avatar
ranger88a
Need the year and make. Sometimes there is still a tag on the side of the trans. which will help.
Old Jun 11, 2008 | 08:11 PM
Rockledge's Avatar
Rockledge
Check out: Ford Door Sticker Decoder
T = Four-speed automatic (4R44E).
D = Five-speed automatic (5R55E).
M = Five-speed manual (M5R1).
H = Single speed (electric).
Old Jun 12, 2008 | 12:11 AM
Bear River's Avatar
Bear River
Former ******
Technically, all the Automatics are derived from the A4LD, which is derived from an even earlier 3 speed. Over the years the trans has evolved to become more refined and increasingly electronic. The early versions used hydraulic governors, and vacuum modulators to regulate the shifting, with later adaptations for computer controlled OD engagement and TC lockup. The 4R44E has a fully electronic control. The computer decides when to shift each gear based upon speed, load, and throttle position. The 5R55E is the same, except it engages OD on top of 1st gear to create a gear split between 1st and second, an extra speed basically.
The codes listed by Rockledge are right on. Use that to determine which trans you actually have.
All the electronic trannies share a weakness that has to do with the shift strategy. Basically, they are designed to slip a little each time the shift in a effort to make the shifts smoother. This wears them out faster, and produces more heat. Shift kits to firm up the shifts correct the problem and make the trannies last much longer and they can handle more stress. The solenoids on some years also have problems. I don't have the link, but there are outfits that redo the valve bodies to increase the fluid pressures and strengthen the tranny.
Despite the weaknesses, if the fluid is replaced with new fluid every 30,000 miles, most failures could be avoided.
Old Nov 11, 2009 | 03:31 PM
gino76's Avatar
gino76
i bought a '01 w/ a 4r44e at 99k. now has 110k and trans after warming up(10 mins)wont shift from 2-3rd unless i back off throttle.or it hits nuetral type setting.2wd and fluid smells.i am old school worried that if i r&r fluid &filter,truck will slip and be dead in water!i am really not as educated about the computer conrols and various sensors.doing nothing is never an option.advice for this situation any one?tx
Tim Young
6.7L Power Stroke Diesel
45
Oct 29, 2013 03:43 PM
JayderAK
1978 - 1996 Big Bronco
Mar 29, 2013 07:12 PM
FUJINAMI1293
18
Jan 4, 2013 01:18 PM
5 Star Tuning
South Carolina Chapter
13
Nov 12, 2008 10:44 AM
rsvlmarvin
May 29, 2002 09:06 PM
