specs on fuel supply to the heads...
I'm going for my WVO conversion.
I'm creating a complete second fuel system using a hydraulic pump for the WVO.
Now, I need to "Tee" into the existing fuel supply to the heads, what thread and size are they?
Also, I want to install a drain valve on each head, (where the fuel return was on buses etc), what size is that plug???
Thanks in advance.
Thanks in advance.
I want to put a splitter on each head where the line comes from the bowl.
I'm putting a check valve on each diesel supply line, and same with WVO.
This way, if theres any WVO problems, the diesel starts flowing.
I wanted to put a drain valve on each head to drain in the event of forgetting to shut if off on diesel, or getting rid of any air in heads during setup.
444dieselrod
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-25-2013 03:23 PM
lio45
08-03-2012 03:52 PM
Pocket
02-14-2009 04:17 PM
parkland
08-26-2008 06:30 PM
mongo75
19
03-17-2007 09:53 PM
