specs on fuel supply to the heads...
Old 06-11-2008, 03:37 PM
parkland's Avatar
parkland
parkland is offline
I'm going for my WVO conversion.
I'm creating a complete second fuel system using a hydraulic pump for the WVO.
Now, I need to "Tee" into the existing fuel supply to the heads, what thread and size are they?
Also, I want to install a drain valve on each head, (where the fuel return was on buses etc), what size is that plug???
Thanks in advance.
Old 06-11-2008, 11:30 PM
jtharvey's Avatar
jtharvey
jtharvey is offline
Where exactly are you looking to tee into the existing fuel supply. I can tell you that the front and rear ports on the heads themselves are 1/8" NPT.
Old 06-12-2008, 03:21 PM
parkland's Avatar
parkland
parkland is offline
I want to put a splitter on each head where the line comes from the bowl.
I'm putting a check valve on each diesel supply line, and same with WVO.
This way, if theres any WVO problems, the diesel starts flowing.
I wanted to put a drain valve on each head to drain in the event of forgetting to shut if off on diesel, or getting rid of any air in heads during setup.
Old 06-12-2008, 03:29 PM
jtharvey's Avatar
jtharvey
jtharvey is offline
Not sure if this will help, but the fittings in the bowl are 1/8" NPT as well. Unfortunately, I don't know what the actual fuel line itself is. Looks like I'm not much help.
Old 06-12-2008, 05:50 PM
mongo75's Avatar
mongo75
mongo75 is offline
Hey Park, I know you brought this up before- did you get a chance to look at my gallery pics, to see how it's usually done to run WVO, plus get a cackle cure out if it at the same time?
444dieselrod
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-25-2013 03:23 PM
lio45
08-03-2012 03:52 PM
Pocket
02-14-2009 04:17 PM
parkland
08-26-2008 06:30 PM
mongo75
19
03-17-2007 09:53 PM
Quick Reply: specs on fuel supply to the heads...
