Finally have a custom fuel system for WVO.....sorta...
Well, I have been planning a wVO setup for a while, and things are finally cooking!
For thoise of you who dont know, I am making a complete 2nd fuel system, fed into the heads at the opposite ends of the stock system, which will be getting check valves to prevent WVO from going into the diesel system.
I have a oil furnace pump, that I have pumped lots of WVO, and it has been sitting with W|VO in it for 6 months, and today I opened her up, and everything seems 100%.
This pump will be inside the steel heated tank, and the fuel will be regulated at 10-15 psi higher that the stock system, so that i can switch simply by turning the WVO system on.
Its gonna be sweet, i'm still debating on what style of lines to run to the engine, flexible, plastic, copper, rubber, then I have to decide the internal fuel lines too, (hose in hose setup)
but ist gonna be sweet...
onthemoveactivist
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-13-2014 12:42 AM
444dieselrod
09-07-2012 10:01 AM
timmyboy76
05-11-2012 11:05 AM
2002exPSD
06-30-2011 12:29 PM
