Sponsored by: Innova
Amp/Sub Problems
Old Jun 3, 2002 | 04:46 PM
odinmurphy's Avatar
odinmurphy
Amp/Sub Problems
Old Jun 4, 2002 | 08:56 PM
bigredford04's Avatar
bigredford04
Amp/Sub Problems
Today while driving around I went to turn up the bass one notch on my deck and when I did my subs cut off. I checked all the fuses, still good. When I let it sit for a little while and turn it on again they'll hit once then cut off again. I'll be going over it tomorrow w/ a volt meter but i just want to get some preliminary ideas of what to look for. Thx.
Texas A&M Off-Road
`95 F150 4x4 5.0
33" BFG KMs
Old Jun 4, 2002 | 10:18 PM
big_red_59's Avatar
big_red_59
Amp/Sub Problems
How long does it take to first cut out? And how long does it take to start back up again. I had this problem once due to heat. I'd crank it up and the amp would be working hard creating a lot of heat. Wouldn't take long for it to overheat and cut out.
Old Jun 5, 2002 | 12:37 PM
akford351's Avatar
akford351
Amp/Sub Problems
You might want to check all of your wires thoroughly. You might have chafed wire w/bare wire touching each other... which in turn would cause a short. Either that or your amp might be fried. My friend had a cheap amp and that's was his was doing after about a month. Good luck w/yer prob...
Ray
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Oklahoma Chapter
Apr 11, 2003 10:33 PM
walterdanek
16
Feb 16, 2001 07:56 PM
