help... need a D50 stub shaft
Old Jun 10, 2008 | 09:28 PM
Boss300's Avatar
Boss300
I recently had a front wheel bearing go out (got 195000 out of the originals) and noticed when it was apart that the stub shaft where the little needle bearing rides has a groove wore in it as wide as the needle bearings and when everything is together there is slop in my axle shaft there. Welding shop says you cant weld it up and turn it down because its hardened and ford wants 600 bucks for a new one. Other than a junk yard, where could I find a good shaft. Its an early 99 F350 4x4 SRW. Anyone else ever had this problem? If so what did you do?
Old Jun 10, 2008 | 10:20 PM
J&JProperty's Avatar
J&JProperty
I had to replace one a couple years ago, go to car-part.com. You can search for the part you need and it has the inter-change for all the model years they fit. My axle shaft ran 250.00 including shipped to my door. You can also check with a driveline shop to see if they can fit a carrier bearing on it.
Old Jun 11, 2008 | 05:47 AM
John311t's Avatar
John311t
Part Number : 4C3Z-3B387-AA
Outer stub shaft.
Part Number: C6TZ-3123A
Needle Bearing Replacement
Both of these are ford parts numbers. This is not the $600 shaft, this is just the outer stub shaft, and it is around $120. The needle bearing I paid about $14 for.
Old Jun 11, 2008 | 06:07 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by John311t
Part Number : 4C3Z-3B387-AA .. Outer stub shaft.
Part Number: C6TZ-3123A .. Needle Bearing Replacement
4C3Z3B387AA / MSRP: $194.82 / ftepartsguy.com price: $140.27
C6TZ3123A / MSRP: $14.98 / ftepartsguy.com price: $10.79
FTE sponsor: ftepartsguy: Ed Olson at Parr Ford in Bremerton WA.
btw: When typing Ford part numbers into websites, the hyphens and any spaces need to be removed, otherwise you'll get the message: No parts found.
Old Jun 11, 2008 | 09:12 PM
Boss300's Avatar
Boss300
Thanks guys, I took those numbers to my ford dealer and my parts guy hooked me up for $130. I thought I was gonna have a headache.
Old Jun 11, 2008 | 10:39 PM
mueckster's Avatar
mueckster
Good deal! I'm glad they gave you a decent price on the parts.
Old Jun 12, 2008 | 06:27 AM
NumberDummy
You better stay very friendly with that parts guy, the price you paid is dealer cost + 5%.
The best price I received on parts I purchased during my 35 years behind the parts counter was dealer cost + 10%.
Most dealers only give 20-25% off retail on parts sold to the trade.
Cost + 5% is a give away deal.
tshrager
17
Feb 26, 2013 09:29 PM
dvw70
Jan 4, 2011 01:56 AM
n20
20
Sep 13, 2010 05:12 PM
mustange70
Offroad & 4x4
Dec 29, 2005 07:10 PM
Eddie
Offroad & 4x4
Jan 30, 2000 06:40 PM
