Trans temp probe size?
Old Jun 10, 2008 | 05:41 PM
03F2507.3's Avatar
03F2507.3
I did a search and cant find the answer. I read in a post that the size of the probe has to be shorter than normal?? Is this true??
I bought an autometer ultralite II trans temp electric guage.
Thanks
Old Jun 12, 2008 | 07:55 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
A real long probe will bottom in the port before the threads tighten.
Old Jun 12, 2008 | 08:56 PM
03F2507.3's Avatar
03F2507.3
Thanks for the info. I was hoping for a pic of the proper size probe so I can compare.
Old Jun 12, 2008 | 09:14 PM
Dieselmanor's Avatar
Dieselmanor
FTE Sponsor
We have some info on our site here: 3-Gauge Install Pictures
The thread size on most senders is 1/8:NPT. the same thread size as the test port. The length can be a concern. The Autometer and DiPricol gauges we sell all have short probes, but the ISSPROs are a bit longer. To prevent the ISSPRO probes from bottoming out in the port you should use 2-3 wraps of teflon tape and screw it in until snug. That's it. It only needs to be secure and not leak. The ISSPRO probes don't need to make metal contact for grounding because they have their own gnd. wire. If you are still concerne we sell an item called the sender extender that in essence lengthens the depth. DieselManor - Accessories
Old Jun 12, 2008 | 09:25 PM
03F2507.3's Avatar
03F2507.3
Thanks for the info. Im hoping the guage I have has the short probe. I am installing on Monday so we will see.
Old Jun 12, 2008 | 11:53 PM
superduty4x4's Avatar
superduty4x4
I bought/installed an Isspro kit from these folks and didn't have any problems with the trans temp sender bottoming out, and no leaks that I've noticed so far. I think it's just a luck of the draw thing.
Old Jun 13, 2008 | 06:39 AM
Dieselmanor
FTE Sponsor
The only probles we seen, and it's rare, is when people tighten them too much, causing the tip of the probe to contact inside the port. What then happens is the brass tip cracks and fluid starts leaking out where the wires enter the probe (in the potting compound of the sender). Like I said, it's very rare.
larspetter123
23
Aug 19, 2011 04:54 PM
triton185
Jul 2, 2007 10:52 AM
YellerMax
Dec 7, 2006 12:12 PM
mizzitch
Dec 6, 2006 07:45 PM
agreder
Apr 27, 2005 05:43 AM
