Sponsored by: Auxito
SVT Lightning Engine Conversion
Old Jun 10, 2008 | 12:39 PM
01CRAZY_COOTER01's Avatar
01CRAZY_COOTER01
Howdy Everybody,
I Have A 1997 F-150 4.6L 5 Speed 4x4 And I Am Fixing To Embark On An Engine Swap. I Will Be Placing An SVT Lightning Engine Under The Hood. If I'm Not Mistaken The Bell Housing Pattern Is The Same, If Not I Should Be Able To Figure Something Out. My Main Concern Is The PCM Configuration, Due To The Fact I Have A 5 Speed And The Lightning Is Automatic...What Could I Do To Not Screw Up The Function Of The Engine Due To The PCM Searching For A Trans. Signal? I Would Greatly Appreciate Anyone And Everyone's Input On This Concern And Any Other Comments About The Project. Thanks!
Old Jun 10, 2008 | 12:47 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
well your 5 speed wont take that power... no way no how.... so you will need the tranny from the lightning with it. When you get those you might as well get the ecm and all harness's that go with that tranny and engine... It should take care of your entire swap.. You will probably need a heavier fuel pump as well. I think the lightning has a larger one.
Old Jun 10, 2008 | 01:16 PM
KingRanchMan02's Avatar
KingRanchMan02
I will second what Burns said.
Old Jun 10, 2008 | 04:45 PM
BLK94F150's Avatar
BLK94F150
Although it's not exactly a fast shifting tranny, a ZF-6 would probably work. I think they are making a short shift lever for it.
Mike
Old Jun 10, 2008 | 07:14 PM
01CRAZY_COOTER01
As For The Tranny I Had Actually Thought About The ZF-6 Or Quite Possible Building A Straight Shift Specifically For This Truck. I've Made A Few Phone Calls To JASPER And They Can Build Whatever I Want. I Absolutely Hate Automatic Transmissions, I've Never Owned One, And Hopefully Never Will. That's Why My Concern Is The PCM Searching For A Trans Signal. If Worst Comes To Worst I Will Send The PCM Off And Get It Re-Programmed. I've Got A Regular 5.4L But Why Settle?...Gas Ain't Gettin' No Cheaper, So What's Another Couple Miles Less Per Gallon?...I Mean Come On, A 4x4 5 Speed Lightning...How Kick *** Would That Be?
Old Jun 10, 2008 | 11:50 PM
BLK94F150's Avatar
BLK94F150
I'd say custom programming is pretty much going to be needed.
Mike
Old Jun 11, 2008 | 06:53 PM
BURNSTOUGHFORD
Ya, would love to get my truck retuned for the 5.4l...
Old Jun 25, 2008 | 01:48 PM
01CRAZY_COOTER01
That's What I Had Intended On...If I'm Not Mistaken TS Performance In Bowling Green Can Re-Program It For Me...If Not Does Anybody Know Who Can?
Old Jun 25, 2008 | 05:50 PM
galaxie641's Avatar
galaxie641
I would think if you bought a tuner from Troyer Performance they could put a tune in it, actually they could probably run at least 3 tunes in it.
Old Jul 1, 2008 | 01:35 PM
01CRAZY_COOTER01
What's Their Contact Info, I May Just Have To Give Them A Holler!!
Old Jul 2, 2008 | 09:44 PM
stephen.osborne1's Avatar
stephen.osborne1
Let us know what you figure out... I was thinking about dropping a lightning motor into my '00. Or maybe at least a lincoln 4v 5.4. I already have a 2v 5.4, but it's getting a little tired. I'd love a z-f 6 but don't mind the 4r100. I think I'll have my hand full enough with the engine swap alone.
Old Jul 3, 2008 | 12:43 PM
galaxie641's Avatar
galaxie641
Troyer Performance
ncalf150
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jan 30, 2023 08:34 PM
Justin Moons Simon
1997 - 2003 F150
Feb 3, 2016 11:26 AM
jberylecrider
33
May 24, 2015 11:49 PM
hugo_7
Engine Swaps
May 9, 2014 09:26 AM
