Sponsored by: Auxito
Engine Light Is On
Old Jun 10, 2008 | 12:18 PM
canadianhunter's Avatar
canadianhunter
Engine Light Is On
The engine light is on on my 98 Ford F-150. Code reader says check TSB 98-06-11 and also says PO-171 and PO-174. Can't seem to find a service bulletin list. Would appreiate any help I can get.
Thank-you.
Old Jun 10, 2008 | 12:58 PM
KingRanchMan02's Avatar
KingRanchMan02
Take a look at the top of this forum. there is a pull down for "Recalls/TSBs" click there and then on Full Text TSBs. Also do a search for the DTCs that you have. there is a lot of information on the forum about those particular codes that you will find. It basically comes down to there being a vacuum leak. Good luck!
Old Jun 10, 2008 | 01:09 PM
ncranchero's Avatar
ncranchero
I don't find a TSB 98-06-11 on Fords site for the F150.
Go to the top of the page here and search "P0171 + P0174" for many pages of good info.
Old Jun 10, 2008 | 05:54 PM
steve(ill)'s Avatar
steve(ill)
- P0171 and p0174 with Fords - OBD-Codes.com
Old Jun 10, 2008 | 07:49 PM
canadianhunter
Thanks for the replys.
Anyone know what service techs use to spray on hoses etc. to check for vaccum leaks?
Old Jun 10, 2008 | 08:38 PM
Lavern's Avatar
Lavern
soapy water might work...do you find out what all the codes are? if you didnt let me know what ones you need i have a ford service cd that sould have the codes on them.
Old Jun 10, 2008 | 10:34 PM
galaxie641's Avatar
galaxie641
Easiest way to find a vacuum leak is with propane or some kind of MAF/TB cleaner that is flammable. If you hit the open leak the engine will rev. Soapy water works for pressurized leaks.
Old Jun 11, 2008 | 06:38 AM
Ron W.'s Avatar
Ron W.
First off
You've got a code reader that references TSB's? way cool what kind and model.
Secondly
Seems like alot of the time when you get these 2 codes it turns out to be the 90 degree rubber boot (connector) on the PCV line has deteriorated and is sucking air, easy to check and repair.
Good luck
Old Jun 11, 2008 | 06:45 AM
projectSHO89's Avatar
projectSHO89
Originally Posted by Ron W.
First off
Secondly
Good luck
90% (or better) that this is the problem. With odds like that, just check it first.
Steve
Old Jun 11, 2008 | 10:07 AM
LxMan1's Avatar
LxMan1
Yep dirty MAF or bad PCV hose elbow are the two most common reasons.
Old Jun 11, 2008 | 10:21 AM
canadianhunter
The code reader was at our local small auto repair shop in our small town, Brand ???. The mechanic ( a long time Ford Mec.) did spend a lot of time spraying something to find a vaccum leak, no luck. I will try again. They didn't have the ford TSB list that the reader flagged. I found the TSB was listed under 97 trucks. Maybe flagged cause it was order as soon as ordering was possible. Any it was for having the wrong air cleaner and MAF sensor, if it was wrong it should have flagged in the 1st 10 years.
Some of the suggestions were to clean the MAF sensor, I did as I had had a K&N filter on . Took it off now. Will try driving it as it take about 7 starts, 4or5 runs before the check engine light flags.
Thanks for now, I will keep you posted.
Bye the way this is one great site.
Old Jun 11, 2008 | 10:33 AM
canadianhunter
I must add that the local shop does not have all the latest ford equipment, but are trying. Also trying not to waste my money by putting the wrong things on. Went here because I trust them and it is almost 100 miles to a good ford dealership.
Old Jul 3, 2008 | 06:13 PM
canadianhunter
Just to let everyone know that cleaning the MAF sensor has cleared my engine light on problem to date.
Thanks for the help.
