Sponsored by: Innova
1997 Explorer 4 WD CD Changer Help!
Old May 27, 2002 | 12:08 PM
n2racin's Avatar
n2racin
Old Jun 14, 2002 | 04:28 PM
jforte's Avatar
jforte
[updated:LAST EDITED ON 14-Jun-02 AT 05:31 PM (EST)]I am attempting to install a cd changer and need to know which side the wiring harness is in the back panels?
The radio has a cd button and I have the changer, is there anything else I need to know or have to buy?
Hope to hear from ANYONE!
Thanks
John
Old Jun 24, 2002 | 03:54 PM
gtyates's Avatar
gtyates
Assuming you are adding a factory CD changer, you will need to get a wiring harness from your Ford dealer. It will cost around $50.00. What you have to do is, pull the head unit out of the dash. Then, disconnect the factory wiring from the head unit, plug it into the new wiring harness, then plug the harness into the back of the head unit. Also, you will have to remove the console top and run the new wiring harness through the console to the console mounted CD changer. For whatever reason, Ford does not include the wiring in the console for a changer unless they put it in at the factory. I did this on my 97 XLT and did not have any problems installing the harness or the CD changer. I bought my changer off of ebay for $180, including shipping.
Good luck!!
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
