hi guys,
i got a 2005 f150 (5.4L) i would like to check/top off the freon. I got two fill valves, one near the radiator and one near the firewall. one is also thicker than the other. i know one has to be the suction side. does anyone know which is which? or where i can find this info?
When you get the can and "fill hose" The hose will have a quick disconnect plug on the end. It can only connect to the low pressure port on the system.
You really need to get a gage to measure the high pressure side though.
If you think you have a leak get some R-134a with a leak detection dye etc...
the air doesn't seem to get that cold anymore,and it seems to take longer to cool the truck down than it use to. i was going to go to the auto parts store and get the freon with the guage built onto the tank, and just check if i might be low. i have done it before on older cars but i couldn't remmember which side of the hose was which.
i don't know for sure it needs to be topped off. i just figured with the symptoms i described it might need some. if you think it might cause more harm than good to top it off, maybe i will just leave it alone. i'm sure if i had a leak being that it is a 2005 i would of lost all thee freon by now.
