MAP sensor hookup relocation?
Old Jun 5, 2008 | 08:11 PM
Madmaxz's Avatar
Madmaxz
i was reading a post where guys were talking moving the map hookup to the turbo outlet so it would see a higher reading sooner and the PCM fuel sooner and higher during acceleration. anyone do this?
heres the post:
https://www.ford-trucks.com/forums/6...fueling-2.html
Old Jun 5, 2008 | 08:14 PM
jhand124's Avatar
jhand124
heres the post:
I would just put in a OBA LINky
Old Jun 5, 2008 | 08:25 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Here is where mine's at.
Old Jun 5, 2008 | 08:27 PM
Madmaxz's Avatar
Madmaxz
nice, did it do anything for ya?? and whats that other tube under it? :EDIT: NM boost guage right?
Old Jun 5, 2008 | 08:51 PM
PowerstrokeJunkie
yes that is my boost gauge..... didnt seee a damn difference... i put it there because i heard it would make a difference... plus my boost reference to my fuel regulator takes up the original spot...
Old Jun 5, 2008 | 10:55 PM
jtharvey's Avatar
jtharvey
I moved mine and thought it felt as if the turbo spooled just a tad quicker than before.
Jason, the OBA won't make any difference here. The thought is if you move the MAP line to the turbo outlet (hot) side of the spider rather than the post IC (cool) side of the spider, the MAP sensor will see boost a touch quicker and result in fueling a bit sooner. The OBA will work the same no matter which side of the spider the MAP line is on.
Old Jun 5, 2008 | 11:30 PM
Tenn01PSD350's Avatar
Tenn01PSD350
So, still not making any serious power then Kris? I'm not either man. PMR world we live in.
Old Jun 5, 2008 | 11:36 PM
jhand124's Avatar
jhand124
I see this know, I thought he was trying some boost fool thing, thanks for the clarification.
Old Jun 6, 2008 | 07:54 AM
c00nhunterjoe's Avatar
c00nhunterjoe
this is a common mod on our obs trucks when we instal intercoolers, there is a definate decrease in turbo lag on our trucks. there is no physical power gain from it. this mod may not be as noticable on your trucks since you run a smaller housing on the turbos but our bigger 1.15 housing you see a fairly large difference in response from the engine.
on mine i just got a brass tire valve stem from napa and installed it in the turbo tube, cost 2 bucks and took less then 5 minutes to do. i would still say its worth doing on your trucks even if the diference is minor, for a few dollars any increase is worth that
Old Jun 6, 2008 | 01:10 PM
Madmaxz's Avatar
Madmaxz
coonhunter did you just tap the IC pipe or how did you mount that fitting? seems like the ic pipe is too thin to tap
Old Jun 6, 2008 | 02:17 PM
ron's power stroke's Avatar
ron's power stroke
a metal tire valve stem is always flared like a flat washer and has a rubber on the inside and held on with a nut and rubber washer on the out side.....make sure the core is out of the stem when you plug in the map line..
Old Jun 6, 2008 | 03:06 PM
Madmaxz's Avatar
Madmaxz
got it. yup picked up a threaded valve stem i see what your saying now.
Old Jun 6, 2008 | 04:43 PM
Madmaxz's Avatar
Madmaxz
finished. took about 15 mins hardest part was finding the threaded valve stem. i can definitely feel a difference it has alittle more pep and i can deff hear the turbo spool sooner. but when i went to remore the end of the hose from the manifold it was really loose it was barely on there at all so im sure it was leaking pressure... oh well nice simple mod.
