Bronco II Ford Bronco II
'88 Bronco II project
Old Sep 25, 2008 | 12:03 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
Dave, what year is your Ranchero? I have a 64. I need some rear axle parts. Spring/shock mounting plates and rear brake line junction block. Dan.
Old Oct 13, 2008 | 08:35 AM
Dave Severson's Avatar
Dave Severson
Mine Ranchero is a '67... Sorry, all the stock rear end parts were gone long ago....
Old Oct 13, 2008 | 08:41 AM
Dave Severson
Originally Posted by mudslinging79
you gonna do a top chop also? would look good if the top was lowered a few inches...
Funny you should mention that! Finally got the opportunity to spend some time on the Bronco II and started the chop. I laid the windshield back first to the angle I wanted, then started cutting the posts, etc.... Going good so far, the chop is 3 1/4", have things somewhat tacked back together now and it's looking good. Added some pictures in my gallery if you're interested. Anyway, having some fun with it and trying to just build me another unique Hot Rod Ford....
Old Oct 13, 2008 | 06:27 PM
mudslinging79's Avatar
mudslinging79
a auto glass shop should be able to special order or even cut down the existing glass if need be, my dad had to do that for his 47 dodge.
Old Oct 13, 2008 | 09:07 PM
Dave Severson
I'm doing a bit different route on this one, left the windshield stock and still installed to keep the stock size then pie cut the posts and laid it back about 5 degrees. I won't be using the rear glass, going to make it a sedean delivery----sort of.... Side windows and rear window will be lexan to cut down on weight.... Going to do a bit of bracket racing with it, glass is heavy....but still want to street cruise with it, so the Lexan side windows will be removable...
Old Oct 14, 2008 | 06:53 PM
mudslinging79
and you probably need the oem safety glass windshield for street legal reasons? right?
Old Oct 14, 2008 | 09:01 PM
Dave Severson
Yup, went through the ordeal of getting a windshield made once, $1200.00.
I had a bit of time today to start tacking the pillars back together... Surprised that it actually seems to be bringing the cab into proportion...Always thought they looked too tall, made it's just the big side glass??? Anyway, when I'm all done, doubt it will even look like it was chopped..... Having a blast with it, I'll be glad to get a couple other projects kicked out of the shop and be able to devout more time to the Bronco.
Old Oct 19, 2008 | 05:28 PM
Dave Severson
Spent part of the day on the Bronco. Got the roof pieces tacked back in place and one door cut and fit to the body. Added a few more pictures in my gallery for anyone interested in the progress of the build.
Old Oct 31, 2008 | 07:29 PM
mudslinging79
thought of a possible project, make a bronco 2 into a dually... chop the rear fenders offf of a dually p/u, and you would lose the rear fenders on the b2, grafting, welding... wonder if it would be feasible and if its been done.
Old Nov 1, 2008 | 07:46 PM
Dave Severson
Can't say I've ever seen it done, but anything can be done. Think it would be terribly out of proportion unless the Bronco II was stretched considerably........
Old Nov 1, 2008 | 08:51 PM
mudslinging79
or set op for dually, and run one hellofa wide rear tire set
kmjone00
Jan 6, 2022 08:32 AM
fordslut
Feb 11, 2017 07:30 PM
Blue50F-1
17
Jul 4, 2016 01:41 PM
Nero Morg
Jun 28, 2016 07:53 PM
jwcorder
May 18, 2005 07:56 AM
