Sponsored by: Kumho
03 Taurus Won't Align
Old Jun 4, 2008 | 09:42 PM
CTford's Avatar
CTford
I have a 2003 Taurus Wagon with several problems. I'll list them:
1. Won't align- I've had it done at least 4 times and it still pulls.
2. Extremely fast ball joint wear- got new ones put on and they wore out in 1000 miles
3. slight crunching over bumps
4. shimmy in the steering at speeds over 55
Anyone know whats going on? My theory is that I bent the suspension somehow, but I could be totally off. Also, most important- is it safe to take on a 2000 mile road trip? The ball joint issue really worrys me...
Old Jun 4, 2008 | 10:49 PM
stuart1's Avatar
stuart1
You have a serious concern.
Have the vehicle checked for a bent frame.
Do not drive it far.
Certainly not 2000 miles.
Old Jun 5, 2008 | 01:06 PM
ynevada's Avatar
ynevada
check the tires.
make sure the rack bushings are in good shape.
use QUALITY balljoints. not the cheap auto zone crap. use MOOG.
check the wheel base, side to side.
also, try a different align shop, and TALK to the techs working on it.
on that car, the camber isnt adjustable. (the tech SHOULD be telling you, if the camber is off or not....) so if its off, the only thing they can do is set the toe. if its been wrecked, the steering knuckles bend VERY easily, and will throw the camber off.
most times the wheel base is off aswell. so check that.
Old Jun 8, 2008 | 09:40 AM
blue beast's Avatar
blue beast
Have you done the inner tie rod ends? The ones that go into the rack in pinion is
what I am talking about. You need a gigantic socket to get to them and they will
cause all kinds of havoc when worn out and just replacing the outer ends will not fix.
Also check the mounts of the rack and pinion and see if there is any wear or looseness
there.
Old Jun 9, 2008 | 05:20 PM
CrazyAirman's Avatar
CrazyAirman
Ford has a TSB on the subframe bolts loosening up, Try checking those, if they are loose, it can definately cause some of your issues
Old Jun 10, 2008 | 11:16 PM
partsman01's Avatar
partsman01
there.
Yes, could be inner tie rods, I bought the set that allows you to do them on the car.
Vinford
2009 - 2014 F150
22
Apr 13, 2011 12:07 PM
deckpros
Jun 12, 2007 04:25 PM
Customz
Dec 9, 2006 03:19 PM
hancockr
1983 - 2012 Ranger & B-Series
Oct 3, 2006 11:35 AM
