Alternator question for electrical guru's
Old Jun 5, 2008 | 09:57 PM
  #31
megawatt00's Avatar
megawatt00
Originally Posted by cangim
well I am a little late on the game with this one, but most all the questions have been answered. The only one that I didn't see was can you go to high of amperage, the answer is yes. You start pushing too much current though the stock wiring and it is going to melt. At what point is too much I don't know. I replaced mine with a 140A unit and have been really impressed so far. I bought mine from High Output Large Case Alternator Upgrade for Ford 7.3l, 6.0 & 6.5 Power Stroke Diesel
This is true but in order to do that you would have to go very
high on the amperage. Nice find on the 140 A setup.
Old Jun 5, 2008 | 09:59 PM
  #32
jhand124's Avatar
jhand124
Remember these trucks come with the option for dual alternators, so at 110x2 that would be 220, that amperage will be my next alternator. FWIW I am only on my second alt with 210000 miles (must have got a good one).
Old Jun 5, 2008 | 10:01 PM
  #33
megawatt00's Avatar
megawatt00
True Jason. Wow you did get a good one!
Old Jun 5, 2008 | 10:08 PM
  #34
jhand124's Avatar
jhand124
So with that in mind we may be able to run a dual 135 amp setup 270 amps, about where Parkland is with his mono alt.
Old Jun 5, 2008 | 10:12 PM
  #35
farmdad's Avatar
farmdad
Would dual alternator setups have heavier wiring factory installed? Or a different way of distributing it to the electrical system so all the power doesn't go through one wire? Just wondering.
Old Jun 5, 2008 | 10:56 PM
  #36
KelVarnson's Avatar
KelVarnson
Originally Posted by UP_There
I have a 130amp alternator, and I"m going with a bigger one next time. My headlights dim at night when I've really got the stereo rockin, and the KC's on........that tells me it's working pretty hard even with the 130 amp.
I suspect there's something else going on, like your headlights are sharing some wiring with your stereo. Are the power leads for your stereo connected directly to your battery terminals? If not, if they are connected downstream somewhere, then the current impulses from your stereo could be causing voltage drops in the headlight wiring, and modulating the voltage to the lights.
A 130 amp alternator should be adequate to support just about any car stereo. 130 amps at 14.5 volts is close to two killowatts. How much do your KC's draw?
Also, if you are running heavy loads from dual batteries, you should connect the load between the positive terminal of one battery and the negative terminal on the other. This will result in better load sharing between the batteries, and ultimately better capacity.
Old Jun 5, 2008 | 10:57 PM
  #37
jhand124's Avatar
jhand124
I don't think so, the dual set up is usually for the plow package and I don't think they would want to change the assembly process of the trucks. The trucks are already setup for the dual alts, all you need is the extra alt, diff serpentine belt, and the dual alt radiator hose ( if you ever replace your upper radiator hose that goes the the thermostat get the dual alt replacement, then your hose wont be routed though your serpentine belt).
Old Jun 5, 2008 | 11:03 PM
  #38
twags6's Avatar
twags6
Not exactly..... I remember reading somewhere on here about doing a conversion to dual alts and if you put larger then stock units(110 IIRC, I'll have to check) in, they'd kill each other for some reason. Now this was with them both hooked up like a factory setup with the PCM controlling the charging.
EDIT: Here's the other thread. https://www.ford-trucks.com/forums/5...ternaters.html The PCM's for the dual setups have different programming.
Old Jun 5, 2008 | 11:28 PM
  #39
jhand124's Avatar
jhand124
That being the case (read till page 3 Tenn had a nice post in there) why is my truck setup for the dual alt? It is an early 99 and didn't have the tow or plow package.
edit: I call BS on the different PCM/wiring, I think we would of came across this being an issue by now.
Old Jun 6, 2008 | 07:29 AM
  #40
cangim's Avatar
cangim
If you are using the factory setup for dual alternators, then yes the pcm controls the second one but only when needed. I agree you'd have to be up in the amperage to melt the wire, but with these huge stereos and lights anymore, it doesn't take long to be putting a constant 100A load, some are even 200-300 amp loads with spikes higher than that. Car stereos have just gotten plum crazy with the amount of wattage they are converting. Up to 150A alt, I wouldn't worry about wiring, if you go to a 200A or so, then I'd upgrade the 6 gauge stock to 4 gauge at least. I have modified mine quite a but, but a 4 gauge splitting from alt going to the driver side battery, along with better grounding would be more than adequate. I have been meaning to get to putting a larger ground wire for a while on as well but havene't gotten to it. Less resistance=better charging. May seem overkill but it does work, especially for those that turn everything on, drive five minutes then shut it off.
Old Jun 6, 2008 | 09:16 AM
  #41
Kwikkordead's Avatar
Kwikkordead
I do the same thing. Here is a picture of my setup.
Old Jun 6, 2008 | 12:29 PM
  #42
UP_There's Avatar
UP_There
I'm running about 1300 watts on my stereo, it's not your everyday run of the mill system, I still have good hearing too! Huh...? Did you say something?
Old Jun 6, 2008 | 12:54 PM
  #43
ernesteugene's Avatar
ernesteugene
Originally Posted by F350-6
...So the question is: How important are those extra 20 amps?...do the lower amps lead to a shorter life of the alternator or batteries?..The only additional electrical load would be a CB with small foot warmer, cell phone charger, & occasionally an inverter plugged in to run my laptop.
To put out much heat, that foot warmer might be drawing as much as 30A or more! It sounds like you've got stuff plugged into both the cigar lighter and the auxiliary outlet in the dash? Do you plan to add a hydrogen bubbler anytime soon?
Awhile back when I was posting about the advantages of cold air intakes and how hot it got under the hood, several members commented on how hot their alternators got. At even a 60A load, the alternator is dissipating more than 250W of heat energy, and they run hot. A higher capacity alternator should be designed to handle a higher heat load than a lower capacity unit, and I think it's the heat that eventually kills alternators!
Old Jun 6, 2008 | 01:02 PM
  #44
F350-6's Avatar
F350-6
Thanks Gene. I usually don't keep 2 things plugged in to the outlets. The occasional cell phone while driving, or the laptop with the truck off in a parking lot somewhere.
If it's the heat that's killing the alternators, then I've got plenty of that around here. Maybe I should start taking measurements with an IR thermometer and noting the ambient air temp and trying to compare it with those that either have the stock alternator or one of the nice aftermarket ones.
Old Jun 6, 2008 | 02:29 PM
  #45
ernesteugene
...Thanks Gene....If it's the heat that's killing the alternators, then I've got plenty of that around here. Maybe I should start taking measurements with an IR thermometer and noting the ambient air temp and trying to compare it with those that either have the stock alternator or one of the nice aftermarket ones...
Well since you're also interested in the scientific method, as opposed to just touching it and saying "ouch, that's too hot to be touching" here's a link to alternator temps, and a quote from it...
Alternator Temp
https://www.ford-trucks.com/forums/6...ator-temp.html
Originally Posted by ernesteugene
Here's an exact temp that I measured last Thurs while towing to my current location of Bozeman, MT. I stopped at a rest stop, grabbed my IR thermometer, popped the hood, but first measured all tire, brake, and wheel bearing temps before starting my routine under the hood measurements, so these #'s are after about 5 min at idle with the hood open. Alternator was 205 F, whereas the upper radiator hose (hot one) was 195 F. Ambient air temp was in the 90's, and I got 90 F looking into the front of my Zoodad hole by reaching through the grill. The AIS air box was 100 F, the big hose from the air box to the CCV coupler was 110 F, and the hose from the CCV coupler to the turbo inlet (close to the turbo) was 120 F. The CAC tube from the IC outlet to the intake manifold was 120 F at the connection to the IM, but the IM itself, which is bolted to the turbo was 230 F!!! It would sure be a nice mod to fashion an insulated piece to connect the turbo outlet to the IM instead of a direct metal-to-metal connection!
Prior to making the above measurements, my fan clutch had been locking up during some of the steeper grades, so I know that the under the hood air temps were in excess of 200 F due to the several hours of towing before making these measurements. The above types of measurements are why I claim that an under the hood filter is not the best choice for towing, as it would be drawing air into the turbo that's more than 100 F hotter than with a Zoodad + air box type filter.
As you can see, my alternator was 205 F, and was about the hottest thing under the hood except for the turbo and exhaust manifolds.
