Spark Plugs
Old Jun 5, 2008 | 06:05 PM
76CamperSpecial's Avatar
76CamperSpecial
Seems to me that the Motorcraft plugs are the way to go -- you just need a good solid spark and it seems like Motorcraft fits the bill with a nicely made plug.
One thing that makes a huge difference -- changing all the plugs rather than giving up on a difficult location. Changed mine for the first time after buying the truck earlier this month and found that seven of the plugs were Champions and the eighth was a Motorcraft. Seems the PO had decided that the rear plug on the passenger side (#4 I believe) was too much work.
Made a big difference in the responsiveness of the throttle!
Old Jun 5, 2008 | 09:56 PM
Randomtasker's Avatar
Randomtasker
I will NEVER use Autolites again. I had one sieze in # 5 cylinder, when I went to remove the plug, the part that the socket fits onto and everything above it broke off the threads (which were left behind in my head) and no easy out would remove it. Had to remove the head and take it to a machine shop to fix.. Buy Motorcraft, always dependable. You only need a fancy sparkplug if you have an aftermarket high voltage coil, or a Multiple Discharge Spark system such as MSD, Accel, or Jacobs. I doubt many of us orinary truck guys have those pricey features under our hoods. They are generally reserved for our race or mudder friends who turn in excess of 6000 rpm regularly.
Any self respecting Ford man would NEVER use AC Delcos.... come on! Stick with Motorcraft.
Old Jun 5, 2008 | 10:23 PM
crescentwrencher's Avatar
crescentwrencher
in the old days ford always used champion.
Old Jun 6, 2008 | 11:40 PM
Randomtasker
One more thought on spark plugs.. Anyone know what AC stands for on AC spark plugs??? How about Albert Champion The perfector of the spark plug.
Old Jun 7, 2008 | 04:58 PM
Tedybear's Avatar
Tedybear
umm...after I had one snap off inside a truck? "AC-" as in All Crap?
S-
rocknsoul
Jan 29, 2018 02:52 PM
tobyw
Modular V10 (6.8l)
Oct 9, 2015 05:14 AM
NewXer
2009 - 2014 F150
Feb 27, 2014 06:51 AM
wkbrdtx
17
Jul 14, 2013 02:00 AM
jason86
1997 - 2003 F150
31
Oct 30, 2007 06:02 PM
