1995 2dr 5 spd 4x4 speedometer problem
Old Jun 3, 2008 | 08:49 AM
Bob 79 supercab's Avatar
Bob 79 supercab
I read many posts about speedometer issues and I have learned a lot but I have a couple questions about my specific application.
First off the speedo only jumps a little under hard acceleration other than that nothing. Plus the odometer and cruise are not working either.
It sounds like my 95 has an electronic speedo and I have chnaged the vss in the rear diff with no effect at all. I think I read that there may be one in the transfercase as well. Is that true? Does it effect the speedo and if so where is it.
Any other ideas would be greatly appreciated. I need to get it fixed before I get a speeding ticket.
Thanks,
Bob
Old Jun 3, 2008 | 02:29 PM
87 XLT's Avatar
87 XLT
Don't know about your 95, but on my 97 the rear diff VSS is for the ABS nonsense only.
Theres also a VSS plugged into the drivers side of the trans on a 97. This one is for cruise control & speedometer.
Old Jun 3, 2008 | 02:51 PM
Bear River's Avatar
Bear River
Former ******
I agree, on my '94 Aerostar, the speed sensor is in the back of the transmission. The one in the rear end is just for ABS.
Old Jun 3, 2008 | 05:31 PM
Bob 79 supercab
Excellant! I'll change it tomorrow (if it's in stock) and let you know if it fixes my problem. I'm glad I asked because I thought I read in another post that the other VSS was on the transfer case. Anybody have a part number by chance?
I figured it was the one on rear diff because that's where it was on my '93 Bronco. Oh well...
Old May 28, 2009 | 11:25 PM
Bob 79 supercab
I know it's been a while but I changed the vss in the transfer case and it still does the same thing.
With the key on I can spin the gear on the end on the vss and my speedo reacts. I have changed the little gear on the VSS and it was better for a little while.
The gear inside the TC looks cupped pretty bad so that's got to be my problem.
So here is the big question. Can I change the speedometer gear on the output shaft of the transfer case by remove the driveshaft and then unbolting the yoke and seal? I'm hoping I can get to a snap ring or something and slide out the gear. If not it looks like I'll have to take out the TC and take it apart.
Please help!
Bob
Old May 29, 2009 | 10:28 AM
5.0B2's Avatar
5.0B2
I believe that when you take off the seal it will slide out. They used the pressure of the yoke against it to hold it in place.
Old May 29, 2009 | 10:36 AM
5.0B2's Avatar
5.0B2
Sorry, that was on the that was on the Borg Warner 1356 in the ful size trucks - don't know about the Explorers
76ranger
Mar 13, 2011 09:12 PM
ken selvy
Aug 30, 2006 03:07 PM
crosbo
Jun 17, 2006 11:15 AM
mchild
Sep 14, 2003 02:20 AM
mchild
Aug 31, 2003 12:35 AM
