Sand Blaster
Old Jun 3, 2008 | 06:57 AM
slowfour's Avatar
slowfour
Sand Blaster
Has anyone tried using a small sandblaster with their home compressor?
I have a 150 lb campressor, would this be enough to remove small areas of paint/rust from my car?
Old Jun 3, 2008 | 08:51 AM
jroehl's Avatar
jroehl
150 psi means virtually nothing on a compressor. What you need to know is the airflow at the pressure your tool operates. And sandblasters use a LOT of air.
You'll be dollars ahead to just use a cheap random-orbit sander (electric) with fine-grit paper for small areas.
Jason
Old Jun 3, 2008 | 05:55 PM
angus's Avatar
angus
It's about the CFM; 8 CFM is about the minimum. But, you may get away with a smaller capacity compressor if you just need to clean a couple of square inches and have a big air tank.
There are places you just can't reach with a sander, like around louvers, or tight corners and recesses.
Old Jun 3, 2008 | 08:16 PM
Ford_Six's Avatar
Ford_Six
I smoked my compressor pretty bad running a small sandblaster, and it is a 60gallon 6 or 7 cfm, I don't remember the specs exactly. But after about two hours, it started knocking and compressor was extremely hot.
Small areas should be ok.
smashclash
Jun 30, 2010 02:16 PM
thefonz#1
Jan 7, 2006 01:22 PM
cigarxtc
Aug 31, 2005 11:45 PM
websthes
Dec 14, 2004 05:07 PM
wayne_j
May 21, 2002 03:57 PM
