Sponsored by: Real Truck
99 F250 SD Front leveling kit Help needed
Old Jun 2, 2008 | 09:23 PM
hutch75's Avatar
hutch75
Hey guys I have a 1999 F250 SD 2wd. I installed the dynastar leveling kit on it . It works great but now I am having a problem with the brake lines getting rubbed my the tires. Anyone have any experence with this.
Old Jun 2, 2008 | 10:46 PM
big poppa's Avatar
big poppa
Maybe some zip ties might help yaa. I don't have a leveling system on yet but i used zip ties when my exhaust came to close to some lines in the back. Hope this helps. Others will chime in.
Old Jun 3, 2008 | 07:47 AM
DAFBFD58's Avatar
DAFBFD58
I would try the zip tie idea. Best I can give you with out seeing the truck
Old Jun 3, 2008 | 10:55 AM
aldridgec's Avatar
aldridgec
You may be able to tweak the metal part at the caliper as well.
Old Mar 10, 2021 | 10:27 AM
99.5_Superduty's Avatar
99.5_Superduty
They make a leveling kit for the front that basically drops the spring hangers 2 inches. Other options are you could X code leaf springs which will lift it up some since your original leafs could be tired and sagging a bit.
Old Mar 10, 2021 | 11:12 AM
crusty old shellback's Avatar
My 01 came with a rough country leveling kit with all new front leaf springs. I have seen no rub issues with my brake lines.
However, in the off road world with long travel suspensions, we use springs to help pull the brake lines out of the way. That way they can still stretch as needed and the spring will pull them back when not needed.
X204R
May 20, 2021 04:05 PM
vntperformance
Maryland Chapter
Aug 29, 2016 03:14 AM
mtelkhunter
Jun 7, 2010 04:00 PM
