Holley Carb Identification
Old Jun 2, 2008 | 11:19 AM
77f2504by4's Avatar
77f2504by4
i have 2 holley carbs that i need identified. i was told one is an 800 or 850cfm. the other i have no clue.
the only numbers i can find are:
LIST-4780
1213
and the other one says:
80467
2653
the second one filled up with waster and the butterfly things are rusted, is it rebuildable? do any parts interchange between the two? if one is 800cfm its way to big for anything i'll ever use but the other i think is 600 or 650 cfm and if i can combine the 2 to make one carb that would save me alot of money!
Old Jun 2, 2008 | 07:07 PM
77f2504by4's Avatar
77f2504by4
actually i found out what i needed to know from holleys website... turns out the 6 was not a 6. it was a 5... one of the carbs is a 800cfm 4150, the other is a 600cfm 4160. will any parts interchange between these two? specifically the base plate with the butterflies?
Old Jun 2, 2008 | 09:05 PM
LxMan1's Avatar
LxMan1
I would like to have a 4780. 800cfm double pumper.
The other is a good 600cfm. I had one on a 460 and it ran fine. It also ran good on my 351W.
The base plates will not interchange, but the 600 should be rebuildable, even if rusted.
Old Jul 5, 2008 | 07:48 AM
kaboom10's Avatar
kaboom10
The baseplates will fit on each other but the throttle blades of the 800cfm will hit on the smaller 600cfm venturis. Vice versa the smaller throttle bores will work on the 800cfm but will restrict the carb down.
lalberts
16
May 13, 2017 10:04 PM
fordboy300
19
Apr 24, 2016 09:18 PM
webster
Oct 30, 2012 02:28 PM
60F100
Mar 26, 2010 06:29 PM
MEPR
Mar 26, 2003 05:59 PM
