Starting Question
Old Jun 2, 2008 | 10:46 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Originally Posted by PaysonPSD
Rick,
With that sensor out a tap on the brake would not turn off the cruise?
Or was the default a no cruise engagement?
No cruise engagement. Mine was leaking brake fluid out to the connection. Took me forever to find that leak. It started off the cruise would just turn off by itself. Then finally quit altogether.
Old Jun 2, 2008 | 10:57 AM
F350-6's Avatar
F350-6
Glenn. Are you having any problems with your cruise? I thought the 0566 only showed up if you were running the switch test.
Have you double checked your TS chip? A loose chip can cause all sorts of problems.
Old Jun 2, 2008 | 11:08 AM
03_PSD's Avatar
03_PSD
No problems at all with cruise. I was leaning towards the TS chip too, I'll take it out and double check the connection.
Old Jun 2, 2008 | 03:21 PM
03_PSD's Avatar
03_PSD
just a bump to get more thoughts
Old Jun 2, 2008 | 07:05 PM
F350-6's Avatar
F350-6
How did it start the rest of the day? A code for a switch test and a non existent 2nd alternator sound like a PCM issue. Loose chip, something got wet, or weak batteries or corroded cables come to mind (at least my simple mind).
Don't forget the first thing that should always be checked on the 7.3 is the oil level.
Old Jun 3, 2008 | 07:02 AM
03_PSD's Avatar
03_PSD
update: everything seems normal. still got the 1211 and the 0541 code yesterday afternoon and checked it again once returning to work. i'm almost certain the chip is/was loose. i'll take it out when i get some time on my hands. thanks for the help guys.
