Intercooler ?
Old Jun 1, 2008 | 08:53 PM
brnab1's Avatar
brnab1
Intercooler ?
I was wondering since you can put a 6.0 intercooler on your truck . If one was 2 buy an aftermarket ( Spearco ,Banks, DI , Ect) would you be better off going w/ one 4 a 6.0 or is the one 4 the 7.3 the best...
Old Jun 1, 2008 | 08:55 PM
Medic 66's Avatar
Medic 66
Alot of people hear talk about using the 6.0 IC so it must not be all that bad....
Old Jun 1, 2008 | 09:21 PM
totin_tools's Avatar
totin_tools
I would say the 6.0, I think it is thicker. Someone more knowlegable than me will probably answer soon. Maybe with the aftermarket ones it doesnt matter as much, but still am not sure.
Old Jun 1, 2008 | 09:56 PM
Goat_roper's Avatar
Goat_roper
I've got the same question posted at the Turboneticsownersclub.com. About all they said was it is bigger and really looks bigger than the stock 6.0. The mounts look the same and the tubes look the same, but it is thicker and taller. If it fits, I may seriously look into one.
Old Jun 1, 2008 | 09:59 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
the 6.0 spearco is alot more than a 7.3 spearco. No reason to buy a 7.3 Spearco, now that the 6.0 is out. They aren't painted, because they didnt even leave room for it, that *****er is BIG.
Old Jun 1, 2008 | 11:15 PM
white Buffalo's Avatar
white Buffalo
I have the 7.3L DI Intercooler (big DIIC) it dropped temps approx. 100 degrees unloaded and 200-250 degrees towing. Nice setup- plug & play install, The new hypermax one is nice also.
Old Jun 2, 2008 | 08:14 PM
brnab1's Avatar
brnab1
Thats what i thought the bigger the better !!!
Old Jun 2, 2008 | 09:21 PM
beanhead6D5's Avatar
beanhead6D5
the only thing bad I read one the 6.0 cooler was the end caps blowing off with higher boost level I thing it was 35 psi or so.that was the factory coolers w/plastic end caps.
Old Jun 3, 2008 | 08:31 AM
Goat_roper's Avatar
Goat_roper
Well, I finally got a reply from the Turbonetics forum discussing the Spearco upgrade.
Here's what they said:
"I don't know that Turbonetics has ever tried switching one to other application wise but seeing as how both kits are priced the same I would go with the one specific to your application unless there is some reason you can't. Both units for both applications provide equal benefits in the areas of pressure drop and thermal efficiency."
I had asked about all us using the 6.0 IC and making it fit as in mounting, etc., so I guess he was being "politically correct" with his answer. The only thing that might give trouble is if the inlet and outlet are 3.5", but there are connector boots that will adapt to the 7.3 tubes, or I suppose someone could take some 3.5" tubing and have it bent to match the smaller tubes on the 7.3 (polished stainless would look good). The only other thing I see (from pictures) is the cooler is quite tall and thick. Like strokin_it said "They aren't painted, because they didnt even leave room for it, that *****er is BIG." Mounts are the same.
Old Jun 3, 2008 | 08:34 AM
Goat_roper's Avatar
Goat_roper
Here are some good pictures of the size comparison:
Spearco Intercoolers pictures from racing photos on webshots
Ford4Life7.3
Jan 15, 2012 07:52 AM
Joe28443
15
Aug 2, 2011 05:45 AM
Adam0331
29
Aug 20, 2009 10:29 AM
schmity
18
Dec 26, 2006 11:29 PM
