Starting Inconsistent - Starter problem?
Old Jun 1, 2008 | 12:28 PM
budabagger's Avatar
budabagger
I tried searching but couldn't find this scenario:
My wife's X every once in a while won't turn over. Radio, air, all instruments available but won't turn over. Usually happens after running in hot weather for a while. If she waits, say 15 minutes, then it starts up just fine.
A friend who used to drive semi's said he used to have the same problem when the wires to the starter get hot. ?? Sound plausible?
Old Jun 1, 2008 | 12:45 PM
william_04_x's Avatar
william_04_x
which motor is in your wife's X, and what year is the truck?
Old Jun 1, 2008 | 01:50 PM
VaSheriff's Avatar
VaSheriff
Sounds like the typical "dead spot" in the starter. I just replaced the starter on my wife's Chvrolet Impala.
Was doing exactly the same thing. Even the wait 15 minutes, then it would start thing.
Haven't had a bit of trouble since I replaced the starter last week.
Old Jun 1, 2008 | 06:00 PM
budabagger's Avatar
budabagger
Thanks, forgot the vehicle info... stupid me...
Its a 2000 X V10.
Thx Sheriff, i guess that is where I am headin'... to a starter replacement...
Old Jun 1, 2008 | 06:20 PM
katiesdad7's Avatar
katiesdad7
Do the new Fords still have the external starter relay? I know the GM's are part of the starter.
Old Jun 1, 2008 | 07:05 PM
Monsta's Avatar
Monsta
Sit. Stay.
I would check the connections and the solenoid before I bought a new starter.
Old Jun 1, 2008 | 07:59 PM
FireTail-AR's Avatar
FireTail-AR
I went through the same thing last year...
I have the same year truck and motor. It turned out to be the starter solenoid. Before I replaced the solenoid, I replaced the starter, that did not fix the problem. I would encourage you to change the solenoid first and see if that fixes the problem. I think it is a $20 part. Good luck.
Old Jun 2, 2008 | 06:45 AM
VaSheriff's Avatar
VaSheriff
Ford OEM solenoid list price is $102.75.
Ford OEM starter list price is $172.05.
If it's the solenoid he can save money.
Old Jun 2, 2008 | 09:58 PM
FireTail-AR
My suggestion may be confusing...
I meant to say I replaced the Starter Solenoid Relay. That was my problem. Thanks.
Old Jun 3, 2008 | 10:09 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
He can save even more money by going on ebay. I just got a NEW HPOP listed at Ford for $700 for $350.
fyredude
Jul 15, 2016 01:56 AM
blwtide1
Sep 20, 2012 01:31 PM
TXTurbo930
Oct 29, 2010 06:41 PM
alpine7572
1997 - 2003 F150
Oct 30, 2005 10:40 AM
rneutron
Apr 9, 2005 09:46 AM
