93 E150 Van 5.0 Overheating
Old Jun 1, 2008 | 08:47 AM
Hndyman's Avatar
Hndyman
Angry 93 E150 Van 5.0 Overheating
Hey Everyone,
I need help if at all possible.
My wifes van started over heating and after inspecting I found the weep hole in the waterpump leaking.
I changed out waterpump but in process 3 bolts broke off,
Tried to rework broken bolts but with no success,
Put everything back together anyway and had no leaks, even replaced T-Stat and had radiator flushed, both by myself and a shop.
Van still over heats, rides near M and A for a bit and then moves to L and stays there unless I am in traffic or on highway and then it overheats.
overheating, not just gauge off because when I raise hood both radiator and reserve tank bubble up and steam can be seen.
I am lost as to what to do now.
Do I need to fix broken bolts, Have been told that as long as there are no leaks it should not matter.
The van was fine before this happened, never over heated unless antifreeze level got too low.
Please help if possible. Thanks in advance
Old Jun 1, 2008 | 12:27 PM
daveshomeservice's Avatar
daveshomeservice
possibly fan clutch.
Old Jun 3, 2008 | 08:48 PM
Hndyman's Avatar
Hndyman
Overheating Follow Up
Hi all,
Turned out that the radiator was more clogged than it was expected, running great now.
Thanks all
genscripter
May 26, 2017 08:45 PM
72CC428
49
May 31, 2016 02:42 AM
talldog
Feb 29, 2016 04:33 PM
lost190
3.8 & 4.2L V6
Jun 1, 2008 06:58 PM
s346k
1983 - 2012 Ranger & B-Series
Nov 18, 2006 03:13 PM
