Turns over slow when hot
Old May 31, 2008 | 11:34 PM
86F150302's Avatar
86F150302
I know there was another thread about this before but I couldn't find it and im sure there was an answer to the question.
Drove my truck alot today testing out my alignment and new tires and it did great except for when it gets about 190* and I turn it off when I go to crank it back it turns over slow. It still cranks up fine just turns over alot slower and kinda worries me. Anything I can do to fix this? New MSD cap/rotor new 9mm ford racing plug wires and new NGK V-power plugs so that rules those things out.
Other then that it was great and I enjoyed driving it instead of the 02 4.2 v6 I have been driving. Didn't enjoy the gas mileage difference though . Deff have to get exhaust put on it too loud when accelerating with open headers.
Old Jun 1, 2008 | 03:07 AM
Sycostang67's Avatar
Sycostang67
Could be the starter going out or getting too hot from the headers. If the headers are real close to the starter you can get heat soak which can cause the slow cranking. Could also be internally corroded battery cables or your battery gets hot and weak as well.
Old Jun 1, 2008 | 09:20 AM
Franklin2's Avatar
Franklin2
Sounds like you also have an aftermarket ignition system. The original duraspark II system had a spark timing retard while cranking feature that lets the engine turn over faster when it's hot.
I would first though, take a piece of aluminum flashing and tie it around the starter to make a heat shield like Sycostang was talking about. If that doesn't help, then turn the timing back a little bit and see if that helps.
Old Jun 1, 2008 | 10:46 PM
86F150302's Avatar
86F150302
Ok ill cover up the starter some. Wouldn't want to have to put in a new one
Maybe wrapping my header in exhaust wrap would keep the starter cool.
Battery is new and cables are new. (forgot to say that)
How could I see what ignition I have? I would think its stock.
Old Jun 2, 2008 | 10:20 AM
Sycostang67
Are all 3 cables new? A lot of times people forget about the solenoid to starter cable.
Old Jun 2, 2008 | 01:41 PM
86F150302's Avatar
86F150302
No the starter cable isn't new that I know of. I haven't replaced it since I have had the truck.
Old Jun 2, 2008 | 02:15 PM
Franklin2's Avatar
Franklin2
Using header wrap will void any header warrenty you have. It makes the headers disintegrate.
Old Jun 2, 2008 | 05:57 PM
victorcharlie's Avatar
victorcharlie
Sounds like you need to retard the timing just a bit.
Old Jun 2, 2008 | 07:45 PM
Franklin2's Avatar
Franklin2
I agree. That would be step 2 after shielding the starter.
Old Jun 2, 2008 | 11:33 PM
86F150302's Avatar
86F150302
ok ill shield the starter and see if that makes a difference and if not ill check out the timing
Jbosel
May 17, 2013 01:27 PM
adam10
Nov 16, 2012 08:22 AM
Firepower flyer
23
Nov 11, 2011 06:18 PM
fishman002
Jun 20, 2011 09:55 PM
saxtonj
Jan 13, 2005 06:58 PM
