Sponsored by: Real Truck
Nerf bars
Old May 31, 2008 | 08:29 PM
jmoore1045's Avatar
jmoore1045
Nerf bars
I just picked up a used set of Ford nerf bars for a 03 cc.
I believe that there are parts missing and I am not sure what is missing and where I might be able to get these parts.
If anyone has a list of parts or an picture of all the parts that would be very heplful.
Thank You
Old Jun 1, 2008 | 07:27 AM
bigskymt's Avatar
bigskymt
Direct Ford Parts, a site sponsor hooked me up. I put factory bars from a 2004 on my 1999, they faxed me over a parts diagram and I was able to pick out the parts I needed. The parts were at my door 3-4 days later.
Direct Ford Parts Genuine Ford Truck Parts Lincoln Mercury Parts OEM Ford Parts and Accessories
Old Jun 1, 2008 | 11:04 AM
bpounds's Avatar
bpounds
Thank You
I don't have a drawing, but the parts in the box are very few. You should have the bars themselves, sheet metal drop brackets, plastic drop bracket covers, capture nuts, and bolts. That's it. The step bars themselves have plastic foot treads and plastic end caps, but they are not sold separately as I understand it. The number of drop brackets and drop bracket covers varies by your cab style. I'm not sure of the quantities, but I think the standard cab and supercab will have 2 brackets per side, and the crew cab will have 4 (?) per side.
I installed the steps on mine about a year ago, and the above is from my memory.
Bill
On edit, I found a drawing in the online shop manual. Hope this link works:
https://www.motorcraftservice.com/pu...20/S6OMAIN.HTM
On second edit, okay the link did not work to go directly to the page. So, use that link to get to the shop manual, then click through BODY, EXTERIOR TRIM AND ORNAMENTATION, RUNNING BOARD to see the exploded diagram.
Old Jun 1, 2008 | 07:56 PM
jmoore1045's Avatar
jmoore1045
Thank You both. Thats what I needed
Old Jun 1, 2008 | 09:14 PM
crazandy's Avatar
crazandy
There were 3 per side on my 07 350 CC LB when I took them off the other weekend. (for sale if anybody wants them)
tunaluvr
Nov 24, 2010 12:42 PM
herrfixit
Sep 23, 2004 08:02 AM
csimon
Mar 30, 2004 05:07 PM
shaner
1997 - 2003 F150
Jun 28, 2001 12:14 PM
96bronco
1978 - 1996 Big Bronco
Apr 21, 2001 01:05 PM
