Leaf spring removal help.
Old May 31, 2008 | 01:35 PM
78ford351m's Avatar
78ford351m
I got the passengers side out. My main problem is the huge bolt in the front. I got the nut off, but I can't get the bolt out on the drivers side. I've pounded, etc. Is there a trick to get it out?
Jason
Old May 31, 2008 | 02:35 PM
oaskills's Avatar
oaskills
I ran into the same problem. I finally got it out by heating the area up with a torch for about 20 min. and then smacking it with another bolt and a sledgehammer. the heating really helped a lot.
Old May 31, 2008 | 03:30 PM
78ford351m's Avatar
78ford351m
I did try heating mine with no luck, but not that long. I'll keep trying. Thanks.
Old May 31, 2008 | 05:16 PM
FloridaStroker's Avatar
FloridaStroker
I used an old bolt that was slightly smaller then the hole and banged it out.
Old May 31, 2008 | 07:42 PM
78ford351m's Avatar
78ford351m
Next problem. This is just a frame, but can I still roll it around with these off? Will the rearend be intact?
Old Jun 1, 2008 | 09:24 AM
FloridaStroker
If you take the leaf springs off the frame and axle, you will lose the rolling chassis. The shocks alone will not keep the axle center or stable. I'm doing a frame off restore my self on my '73, hoping to have my rolling chassis back by the fall. It's a pain in the butt moving the frame, cab, and bed by carrying them instead of rolling them.
Old Jun 1, 2008 | 11:12 PM
bigperm2's Avatar
bigperm2
the problem with the bolt, is that it is rusted in the spring bushing. Your only shot at getting the bolt out intact, is with penetrating oil. If that fails, you can get the spring out by using a cutoff wheel and cutting the bolt between the hanger and the spring (both sides). You will unfortunatley have to replace the bushing, but you probably should anyway since you had a torch on it. Don't spend too much time with the torch on the spring!
Old Jun 2, 2008 | 07:07 AM
78ford351m's Avatar
78ford351m
I can try that and see what happens.
