Sponsored by: Auxito
Changing Antifreeze
Old May 31, 2008 | 09:08 AM
Lance1601's Avatar
Lance1601
Changing Antifreeze
Anyone have a method on changing the antifreeze in these trucks? To my knowledge it's never been changed since we've had it and it's really dark green. Any suggestions?
Old May 31, 2008 | 11:38 AM
galaxie641's Avatar
galaxie641
This is how I do it, hopefully I remember everything:
Open petcock on the bottom P. side of radiator, be careful it is only plastic
Now take the lower radiator hose off of the radiator.
Pull the upper radiator hose off of the engine and remove the T-stat.
Take your garden hose and run water through the block until clear, do the same with the radiator.
Replace hoses and T-stat, the lower hose on the engine side is a PITA.
With the lower hose replaced you can put a gallon of coolant in the radiator through the upper hose if you want. After a gallon of coolant figure you have a pretty good 50/50 mix taking the water left in the eengine into account.
Tighten all hoses and start filling the degas bottle with 50/50 mix coolant and water, it won't take as much as you'd think. You can squeeze the upper hose to get some of the air out of the radiator and suck fluid into the hose.
Now for air bubbles a lot of people leave the degas bottle cap off and let the engine idle until the T-stat opens and the system will burp itself. I've personally never had a problem with air bubbles by just filling the system and checking the fluid level after the first drive.
You can also pull the plugs out of the block to drain coolant. You can also drain the coolant and put in 100% water with a bottle of that cleaner and drive for about a week with it then flush the system. This may be good for yours if it has never been flushed before. This also requires it to not get below freezing for that week.
Old May 31, 2008 | 05:19 PM
mjunk1's Avatar
mjunk1
Great steps... remember that antifreeze is super lethal to dogs and cats and they will try to drink it. Be sure to get rid of it properly, even a little can kill them.
Old May 31, 2008 | 06:04 PM
triton_2002's Avatar
triton_2002
AutoZone.com | Vehicle Selection - Year
Old May 31, 2008 | 08:01 PM
xtrford's Avatar
xtrford
I also take out the block plug on the lower driver side as well....but Galaxie pretty much nailed it.
Old Jun 1, 2008 | 07:29 PM
Lance1601's Avatar
Lance1601
You guys haven't let me down yet (knock on wood). Prestone and tap water OK? Thanks again.
Old Jun 1, 2008 | 08:49 PM
steve(ill)'s Avatar
steve(ill)
distilled water from the grocery store is a littlbe better. has no calcium or minerals that will plate out when it gets hot. not a big dea, but every little bit helps.
Old Jun 1, 2008 | 08:51 PM
xtrford's Avatar
xtrford
You should only put distilled water with the anti-freeze.....too much crap in just plain tap water. The no brainer way is to buy pre-mixed....but half the cost is just water.
Edit: Steve beat me to it.
Old Jun 2, 2008 | 08:50 AM
Lance1601's Avatar
Lance1601
Should I replace the gasket and RTV or is it ok recycle the old one? I'm a little above novice but not exactly an expert.
Old Jun 2, 2008 | 01:34 PM
galaxie641's Avatar
galaxie641
The new T-stat will come with a new gasket IIRC, or an O ring I can't remember which the modulars have. It is one of about 6 different engines I do and I can't remember which it has but the Thermostat should come with a new one be it gasket or O ring.
Old Jun 2, 2008 | 02:19 PM
BLK94F150's Avatar
BLK94F150
Where do you guys get rid of your old coolant?
Mike
Old Jun 2, 2008 | 03:23 PM
xtrford's Avatar
xtrford
I dropped mine off at the local landfill....they have both used oil and antifreeze tanks.
Old Jun 2, 2008 | 03:54 PM
triton_2002
Mike
The autoparts store usually takes it
Old Jun 2, 2008 | 03:57 PM
BLK94F150's Avatar
BLK94F150
My auto parts stores don't take anything but used engine oil. I have a 5 gallon bucket of ATF that is sitting around because they won't take it. Heck, they even complain when I bring them 5 gallons of used engine oil. I usually have to argue with them to take it.
I think I'll just let the dealer flush the coolant and start mixing the ATF into the used engine oil.
Mike
Old Jun 2, 2008 | 04:48 PM
jimm66's Avatar
jimm66
I have the local mechanic do it. $38.00
skytrash
Apr 14, 2014 08:25 PM
88_F0RD
Apr 12, 2014 09:15 PM
Jlowe29101
6.7L Power Stroke Diesel
20
Oct 8, 2011 10:51 PM
MarkMoore
Modular V10 (6.8l)
16
Jan 9, 2008 07:00 PM
clydedog66
Aerostar
Feb 17, 2002 12:56 AM
