C6 kickdown question
Old May 30, 2008 | 06:51 PM
cumminsnorth's Avatar
cumminsnorth
I have a 460 in a 78 f-100 I was wondering if there is anyway to get it to shift at a higher rpm. I have the adjustment screw all the way out already and it is shifting at 3800 I would like to see it shift at 5000rpm.
Thanks
Old May 31, 2008 | 12:13 AM
85e150's Avatar
85e150
Stock 460?
Probably won't go past 4500.
Shift points... modulator, maybe not. May adjust firmness but not wot rpm
Valve body modified with shift kit, I think....
Hold the phone, more answers to come...BUT, if you have a stock 460, it probably won't rev past 4500.
Old May 31, 2008 | 06:36 PM
cumminsnorth
it's not a stock 460 and the C6 already has a stage two shift kit.
Old Jun 1, 2008 | 01:47 PM
mhg's Avatar
mhg
the only way to get this shift point will be
to pull it down to 1st manually any then upshift manually
Old Jun 1, 2008 | 07:23 PM
cumminsnorth
I know that it well shift manually I was wondering if there was any way to raise it when in auto
Old Jun 2, 2008 | 07:32 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The WOT shifting is mainly controlled by the governor, not by the modulator. Modifying governors is a black magic art. You might want to find an older trans shop that works on high performance transmissions. You need to remove weight from the governor weights, or add stronger springs, or a combination of both. It probably will take a bit of trial and error to get where you want to be.
Old Jun 2, 2008 | 07:32 PM
cumminsnorth
Thanks mark
Old Jun 3, 2008 | 05:16 PM
stuart1's Avatar
stuart1
Thanks
If you mean the screw in the modulator it must be turned in, not out.
Turning it in lowers and softens the shift points.
But you will have to get into the governor to raise them a whole bunch..
Old Jun 3, 2008 | 08:57 PM
cumminsnorth
No I meant the screw at the carb but good to know I well check into the screw on the modulator also Thanks
