I have a 460 in a 78 f-100 I was wondering if there is anyway to get it to shift at a higher rpm. I have the adjustment screw all the way out already and it is shifting at 3800 I would like to see it shift at 5000rpm.
The WOT shifting is mainly controlled by the governor, not by the modulator. Modifying governors is a black magic art. You might want to find an older trans shop that works on high performance transmissions. You need to remove weight from the governor weights, or add stronger springs, or a combination of both. It probably will take a bit of trial and error to get where you want to be.
Thanks
If you mean the screw in the modulator it must be turned in, not out.
Turning it in lowers and softens the shift points.
But you will have to get into the governor to raise them a whole bunch..
