Air intake question.....
Old May 30, 2008 | 06:12 PM
Dogwalker418's Avatar
Dogwalker418
I want to put an aftermarket air intake on my 2006 PSD. I am looking at K&N, Banks, and others. Anyone have a preference, pro's and con's, or suggestion? Will this void the manufacturer's warranty?
Old May 30, 2008 | 06:18 PM
Sarge261's Avatar
Sarge261
You are going to find that most people say to stick with the Stock one. It will flow enough air t support 500 hp, it holds 40lbs of dirt and its a great filter. Aslo it traps finer particles which will prevent premature failure of your turbo. Last but not least you only need to replace it when the filterminder tells you too. Most people just do the Zoodad mod.
Sarge
Welcome aboard and spend some time in the tech. folder there is tons of great useful info in there. Hang on tight cause there are a lot of people with knowledge here.
Old May 30, 2008 | 06:29 PM
Dogwalker418
he Zoaad mo Not familar with that. What about a K&N air fle i the stocck box
Old May 30, 2008 | 06:39 PM
Alon@ModBargains's Avatar
Alon@ModBargains
I REALLY like the S&B filters, and have heard nothing but positive reviews from customers about them. You can use coupon code "5offsb" for $5 off of your order
Old May 30, 2008 | 07:03 PM
HeavyAssault's Avatar
HeavyAssault
Stay stock, SARGE261 has the right info.
Old May 30, 2008 | 08:09 PM
69cj's Avatar
69cj
Stay stock and use your money for something worth while and save your engine warranty at the same time.
Old May 30, 2008 | 08:15 PM
adambomb's Avatar
adambomb
i might get the AFE Magnum Stage One. anybody have this or like it? i know stock filters better but i want to get some more air so i have less smoke.
Old May 31, 2008 | 01:44 AM
Candrew's Avatar
Candrew
I had the AFE Stage one but changed back to stock. My AFE is available if you're interested.
Old May 31, 2008 | 01:16 PM
adambomb's Avatar
adambomb
thanks i might be interested if i can't get it the way i am trying. if you don't mind why did you switch back to stock? did you notice any lower EGT's, turbo whistle, power? i am mainly thinking about lowing EGT's.
Old May 31, 2008 | 02:12 PM
denman81's Avatar
denman81
dont bother, changing filters wont do a thing. save up for a water/meth system or an intercooler.
Old May 31, 2008 | 03:52 PM
doubledee715's Avatar
doubledee715
you will have more turbo whistle with an aftermarket intake. Only reason I run mine and not enough evidence to convince me to stick with stock.
Nseal1996
Aug 2, 2014 08:33 PM
trucker01
16
May 10, 2014 09:23 PM
Canadianpowerstroke
Dec 8, 2013 05:25 PM
worstenemy453
52
Dec 27, 2009 08:51 PM
fabian1872
2004 - 2008 F150
Mar 23, 2006 11:01 AM
