Mirror Heater Disconnect
I have an 03 F250 with the heated towing mirrors on it. I've seen several posts with guys asking the same question...but I don't have that problem.
I've owned the truck since Feb of 07 and have been through two winter periods and they're pretty handy. I've scraped ice off the windshield but never had to touch the mirrors.
The only time I've seen water spots on mine is when I wash it and don't dry them before the sun bakes the spots on. If I remember right, the heaters engage when the temps fall below 35...there's no switch for them.
Joe
Joe
Good to hear which wire it is! My driver side one did not work this past winter, and with me moving to Ohio tomorrow, I now know which wire to look for power on!
The heaters may cause water spots on the mirrors but when it is raining, the heaters also keep the mirrors clean. My other trucks don't have heated mirrors and the mirrors are worthless at night in the rain because they are covered with water droplets. The heaters keep the mirrors clear in the rain.
The mirrors are heated all the time. If you have a spare upfitter switch the fix is easy. Replace the mirror heater fuse with a blown fuse and then attach the output wire from the upfitter switch to the load (mirror heater) side of the fuse. Total parts requirement is about 8 inches of wire. To undo the mod, disconnect the wire and replace the blown fuse. I suspect that the heaters will last quite a bit longer this way.
