Alberta Chapter Join Chapter, Leader: Puddy
NEW Alberta Roll Call!
Old May 17, 2012 | 07:33 AM
  #91
seventyseven250's Avatar
seventyseven250
The engine specific forums might also be a good place to check out.
Old May 17, 2012 | 09:48 AM
  #92
dboddy's Avatar
dboddy
I will thanks
Old Sep 9, 2012 | 07:22 AM
  #93
Doonz's Avatar
Doonz
Just joined The AC.
New Baby
The truck the daughter is already two
Old Sep 9, 2012 | 05:22 PM
  #94
dboddy's Avatar
dboddy
Great to see this one start
Old Sep 11, 2012 | 11:12 PM
  #95
dboddy's Avatar
dboddy
How do you put a picture on here?
Old Sep 11, 2012 | 11:40 PM
  #96
Doonz's Avatar
Doonz
I use google's picasa for my online photos. I just copy a link into the message using the add image tags and voila!
Old Sep 29, 2012 | 11:08 PM
  #97
964carrera's Avatar
964carrera
Hey folks, relatively new on here...nice to see some alberta peeps If any of you have some advice with my current issue, it's in the 6.0 section, titled "help, not sure what to do....." any help would be appreciated!! Would love to get my truck on the road.
Old Sep 30, 2012 | 11:38 PM
  #98
dboddy's Avatar
dboddy
Hey all just Checking in
Dose anyone know how a can get better fuel out of my 6.4 getting about 10 miles a gal.
Old Oct 1, 2012 | 07:32 AM
  #99
BigBlackSD08's Avatar
BigBlackSD08
A cold air intake and dpf delete and a chip will almost double your mileage if you are not too hard on the throttle.
Old Oct 1, 2012 | 08:33 PM
  #100
seventyseven250
I haven't got any experience with that particular engine, but "doubling" your mileage isn't typically possible with simple bolt-on mods.
On many vehicles, the ONLY economical mod to improve fuel economy is to tape a raw egg to your gas pedal. I'm not a believer in cold air intakes or chips for fuel economy.
Old Oct 20, 2012 | 09:51 PM
  #101
kornfanjoe's Avatar
kornfanjoe
the 6.4 was when they first introduced the DPF or diesel particulate filter with regeneration cleaning.
what this means is there is a big canister that "collects" all of the soot and exhaust by products, at great restriction to the exhaust system, then when it needs to be cleaned it actually injects diesel fuel into the canister to burn it off more completely. this is the regeneration cycle.
as a whole the dpf robs MAJOR HP causes EXTREME heat (look up ford exhaust fire on youtube, they used to shoot flames out the tailpipes) and uses a lot of fuel as well as causing a major increase in engine load. deleting it (tuning is necessary or else it will go into limp mode) as well as a custom fuel economy tune and an intake will let the truck breathe and flow a million times better, free up lots of power, as well as turbo response (not that the lucky 6.4 needs any!) and greatly increase fuel economy.
its not an exaggeration for those claims. and as for chips and intakes for economy, it does make a difference. especially new engines that are completely electronically controlled. a chip can remove the factory "emissions based" tuning and give it more power that it should have had before, thus providing you with enough torque to coast more often and reduce fuel consumption.
Old Oct 20, 2012 | 10:00 PM
  #102
kornfanjoe's Avatar
kornfanjoe
Im joey, moved to edmonton last august. moved up here for work and an apprenticeship for heavy duty mechanic.
this is my ride, the 400+ hp 6 liter honda eater!
Old Oct 20, 2012 | 10:20 PM
  #103
BigBlackSD08
I have gone from about 30l per 100km down to 17l per 100km on the average and the only other thing that has changed is the tires from 33" to 35" so I can positively say that a chip works IMO.
Old Nov 20, 2012 | 10:56 PM
  #104
thorack's Avatar
thorack
new here
Hi Im ken from Red Deer have a 1992 flair side looking for good pointers to get it running good
Old Nov 22, 2012 | 07:03 AM
  #105
Puddy's Avatar
Puddy
Hey welcome! Make some noise if ya want in here as there isn't too many of us.
Have a 92 flare too. Don't drive it much as its a Summer only Toy.
