Engine poll. 223 or 292
The truck I am restoring(short bed) had the engine changed out at some time to the 6 cyl.
I just pulled the valve cover off the 6 and found that it had either a new or fresh rebuild head on it. I will check compression in the mornin to see if the whole engine has been rebuilt. Looks like it has.
So instead of spending the money to get the 8 cyl. rebuilt. I'll just stuff the 6 back in it. Then all I will need is a new exhaust system. The 6 will cost less in the long run.
And the fact that the 292 is built like a Chevy engine. Dizzy in the back?? What was Ford thinkin ?
I'm glad you are going with the six as well.. I have the 215 in mine, and as soon as I can make the front end stay pointed where I want to go, I'll put a gallon of gas and see how far it takes me. What carb you have on it? I'm thinking of making a maniford and putting two 1 bbls on. Any Ideas of what is better? 1 barrel or a 2 barrel, or two one barrels? Like Rusbukt, I'm not looking for speed, and I'm not wanting to use more gas than I need, but a do want some flair and uniqueness.
Just layed eyes on this set-up.
Ford 223-262 *Truck Combination Dual Header/Intake/adaptor made by Clifford Performance. Nice ! BUT !!
I am syill trying to figure out what this single barrel is. Tag is gone. I's FoMoCo but the numbers on the body don't add up.
It has C3UFR stamped in base plate ?? SM 1.44 on the side. And an H and a Z thrown on to really screw a guy up.
RANGER589
18
06-03-2011 10:03 AM
rusbukt
06-03-2008 08:01 PM
