Sponsored by: Kumho
98 E350 Ball Joint removal
Old May 29, 2008 | 11:16 PM
blazemate123's Avatar
blazemate123
Ok I am down to the part where I remove the knuckle from the spindle and cant get it to move. I have removed the castle nut which holds the lower ball joint. Do I just beat the old ball joint out? Or is there a way to easily remove the spindle from the knuckle? Also do I remove the steering arm??? that is attached to the knuckle or leave it and press the new ball joints in on site?
Old May 30, 2008 | 12:10 PM
Lazy K's Avatar
Lazy K
Get a pickle fork type ball joint seperator ( quite cheap) and use that to seperate the ball joint. You can do it by just bashing with a large hammer but the seperator makes things so much easier. You can use it also for the steering arm and have everything on the bench.
KC98072
Mar 12, 2013 01:16 PM
05SuperPooper
Mar 2, 2012 06:51 PM
Jrodean79
15
May 6, 2010 11:57 PM
Tom Cat
Nov 15, 2003 07:09 PM
Mexray
1978 - 1996 Big Bronco
Mar 29, 2002 09:36 AM
