Sponsored by: Real Truck
Ball Joint Replacement Help
Old Mar 2, 2012 | 10:28 AM
05SuperPooper's Avatar
05SuperPooper
2005 F-250 4wd FX4
I have the hub/brake rotor/caliper/caliper bracket all removed. The upper and lower ball joints are loose. The axle driver side axle shaft needs to be removed to be able to remove the loosened knuckle for ball joint replacement.
How do you remove the axle from the knuckle?
What are the parts on the knuckle and axle that I will need to replace once the axle shaft is out?
I searched this subject but did not find the answer to these questions. I thank you in advance for the helpful responses.
Old Mar 2, 2012 | 04:48 PM
iamrfixit's Avatar
iamrfixit
All the info you need is right here.
https://www.ford-trucks.com/forums/3...ll-joints.html
Knuckle seal is probably holding it in, just pry on either side between the u-joint and axle housing.
On reassembly you need to replace the knuckle seal, the o-ring on the hub assembly and probably the dust seal between the axle housing and U-joint.
Old Mar 2, 2012 | 06:01 PM
Tact's Avatar
Tact
Details with pics:
Ford Super Duty Ball Joint Replacement Procedure | Superdutypsd.com
Old Mar 2, 2012 | 06:51 PM
FordGuy85's Avatar
FordGuy85
Make sure you replace all the seal, dust cover for the axel, and the o ring around your hub assembly.
jawdoc
Jun 20, 2014 06:17 AM
Jowen1017
Mar 17, 2014 09:19 PM
ganzey
Jan 24, 2011 01:14 PM
sosotwo
Oct 23, 2005 06:22 PM
getnbz
Aug 3, 2005 11:07 PM
