2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Alarm question
Old 05-29-2008, 10:19 AM
trpltongue's Avatar
trpltongue
trpltongue is offline
Alarm question
Hey all,
I'm sure someone must have an alarm installed in their expy I was wondering if your puddle lights, running board lights, dome lights, etc. still fade on and off when locking and unlocking the truck with your aftermarket alarm installed?
Thanks,
Russell
Old 05-29-2008, 11:55 AM
berry1234's Avatar
berry1234
berry1234 is offline
It should. What kind of alarm? Where did you get it installed?
Old 05-29-2008, 12:01 PM
SOB Racing's Avatar
SOB Racing
SOB Racing is offline
The lights should work the same as they are hooked to a timmed switch. if they do not you can jump wires to the existing time delated lights to get the samr results.
Old 05-29-2008, 01:27 PM
trpltongue's Avatar
trpltongue
berry1234,
I haven't had the alarm installed yet. I was speaking with an installer and he said that the alarm (code srt6700) dome supervision output was a timed 30second output and that he typically ties it into the domelight switch behind the dash. He said that the lights would no longer fade on and off, rather they would come directly on and then turn off after 30 seconds.
SOB Racing,
Do you happen to know which wire(s) to tie into? The issue the installer brought up was that the GEM disables the lights after a certain amount of time and that the door trigger wire would not be able to turn them on. For whatever reason, he said tying directly into the switch allows you to turn on the lights regardless of the GEM status.
Thanks for the info fellas!
Russell
Old 05-29-2008, 03:49 PM
chuck s's Avatar
chuck s
chuck s is offline
1. Has anyone ever heard a car alarm go off? Sure you have.
2. Has anyone ever seen anyone do anything about it? ...
Factory alarm accomplished all the things an aftermarket alarm does...
-- Chuck
Old 05-29-2008, 05:04 PM
berry1234's Avatar
berry1234
I was going to give my 2 cents on alarms too. Keep your valuables out of your car. Have good insurance. Have gap insurance. Don't park in the ghetto.
Old 05-29-2008, 10:41 PM
fireman28's Avatar
fireman28
fireman28 is offline
I had the dealer install the factory alarm on mine when I got it. It cost me about the same price as an aftermarket and everything worked like it was supposed to. No issues with lighting or hatch popping and it comes with remote start.
Old 05-29-2008, 11:51 PM
Baumbach's Avatar
Baumbach
Baumbach is offline
-- Chuck
This is why I got the Viper 5900 TWO-WAY alarm system; it will alert me up to one mile away, either by beeping or vibrating the remote transmitter
I can remote start it from one mile away, it auto locks the door in 30 seconds after you turn it off, (with key in or out) and you cannot restart it without disabling the alarm. It does a ton of other cool stuff too.
