6.0 engine trouble
Old May 29, 2008 | 09:51 AM
sctrooperlx's Avatar
sctrooperlx
6.0 engine trouble
I have a question for you all.I just bought a 04 f350 6.0 and it has 133k on it.My problem is the truck ran fine when i first got it but when i went to change the oil i used rotella 15w40 because thats what i ran in my 02 7.3L and come to find out i guess you are not supposed to run it in the 6.0 so i changed it out and used motorcraft 15w40.Well ever sence then it will run ruff when i first start it up but once it warms up it seems to be fine.Its got to where if it sets overnight you have to got out and start it up and let it run for 15min before it will even move.So my question is did i screw something up by putting in the rotella oil or could it be something else???Any ideas???
Old May 29, 2008 | 10:00 AM
69cj's Avatar
69cj
Something else, I and many others on this site run Rotello T with excellant results.
Old May 29, 2008 | 10:03 AM
lawnboy1965's Avatar
lawnboy1965
Speaking from experience with Rotella on my 04 F250. I had nothing but problems with my truck. 5 turbos and 5 egr's later I switched to Mystek JT8 and the truck was perfect. Not another problem out of it. I know of other people that run Rotella faithfully and have not had a single problem. For some reason mine did not like it. I wouldnt think that just putting it in and then taking it out would have had time enough to mess any thing up. I would think you have other problems and these guys here I'm sure can elaborate on them.
Old May 29, 2008 | 10:32 AM
sctrooperlx
yea i didnt know,it just seems odd as soon as i changed the oil thats when my problems started.I have ran a code scanner on it and it was clear no codes it passed. So im kinda lost where to go from here.
Old May 29, 2008 | 12:53 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Should be Rotella 5W-40.....not 15W
Old May 29, 2008 | 02:42 PM
69cj's Avatar
69cj
5w40 is synthetic, 15w40 is dino.
Old May 29, 2008 | 02:57 PM
Beerstalker's Avatar
Beerstalker
What oil filter did you use when you changed the oil? If it isn't a Racor filter it could be causing issues.
(Fram, Motorcraft, and a few others are repackaged Racor Filters)
Old May 29, 2008 | 06:23 PM
doubledee715's Avatar
doubledee715
sounds like you should get the newest flash and the oil had nothing to do with it. just a coincidence.
Old May 30, 2008 | 08:39 AM
sctrooperlx
i did use a motorcraft oil filter both times
Old May 30, 2008 | 08:42 AM
sctrooperlx
newest flash? does ford have a new flash for the computer?I know i had to take my SVT focus back to the dealership a few times to get the new flash they had for it.I guess my f350 needs a new flash??
Old May 30, 2008 | 10:19 AM
doubledee715
Yup, call service and say you're having cold start issues and have heard/read about a newer flash that can help eliminate it and you want it done. Whammo! problem solved....hopefully. lol good luck.
Old May 30, 2008 | 10:33 AM
lawnboy1965
Has anyone done the new flash and has it helped with fuel mileage or has it hurt it?
Old May 30, 2008 | 10:44 AM
doubledee715
I've had the new flash done, a long time ago and it did nothing for mpg. It is to aid in cold start up.
Old May 30, 2008 | 12:24 PM
msgtg's Avatar
msgtg
Trooper....revert to the old oil and see what happens.
I used Motorcraft oil until recently and have changed to the Rotella and can't tell a difference. I suspect something else is your culprit.
Joe
Old May 30, 2008 | 01:15 PM
sctrooperlx
yea i will try the flash first and then go from there.Hey msgtg im from wv a little town called oceana wv outside of beckley about 20miles
