sloppy shifter.
Old Dec 1, 2014 | 04:26 PM
tjc transport's Avatar
tjc transport
i ain't rite
sloppy shifter.
my 02 has started developing the sloppy shifter again. if you do not make sure it is in park, it will roll when shut off, and sometimes it will not start unless i pull the shifter up into park, or wiggle it down in neutral.
the shift tube was replaced 7 years ago when i first got the truck because it was broken.
i already checked the two torx screws, and they are tight.
any ideas on where to look next?
Old Dec 1, 2014 | 05:11 PM
Shake-N-Bake's Avatar
Shake-N-Bake
If the screws are tight then your shift tube is likely broken again.
Old Dec 1, 2014 | 05:23 PM
Pikachu's Avatar
Pikachu
The crappy plastic bushings could be worn out. They're available at napa for a few bucks, if that turns out to be the problem. Grease them up well if you change them.
Old Dec 1, 2014 | 05:52 PM
tjc transport
i ain't rite
under hood and down at trans?
Old Dec 1, 2014 | 05:53 PM
sgarder's Avatar
sgarder
Check for slop between the shift lever itself and the shift tube. There is a rubber damper that that takes up slop also. Ford part # 3L3Z-7C130-AA.
Old Dec 1, 2014 | 05:54 PM
tjc transport
i ain't rite
if the shift tube was broken again, it would not do anything like it was when i got it, no?
Old Dec 1, 2014 | 05:57 PM
sgarder's Avatar
sgarder
I think Pikachu means the bushings on the steering column, that support the shifting tube, that the torque screws are bolted to.
Old Dec 1, 2014 | 06:05 PM
sgarder's Avatar
sgarder
If the shift tube was broken. I don't think the shift lever would do much of anything except flop all over, and not move the actual gear select cable.
Old Dec 1, 2014 | 06:47 PM
F350-6's Avatar
F350-6
Is the pointer off or is it accurate?
Old Dec 1, 2014 | 07:11 PM
Pikachu's Avatar
Pikachu
Correct; those are what I meant.
Old Dec 1, 2014 | 10:48 PM
Vinford's Avatar
Vinford
Ive got the same thing happening on my 02.
Any tech threads on this?
Old Dec 2, 2014 | 02:46 AM
Supercab's Avatar
Supercab
Where are the torx screws? mine is getting loose.....
Old Dec 2, 2014 | 03:50 AM
tjc transport
i ain't rite
that is what it was doing when i got it.
had it towed to the body shop where they diagnosed it, and put a new shift tube in it.
pointer is accurate.
that all seems tight. with the shifter movement, the piece the torx screws attach moves accordingly. it looks like it is after the steering column.
Old Dec 2, 2014 | 05:47 AM
Pikachu's Avatar
Pikachu
I think there's been a misunderstanding somewhere. The bushings are held in place by clamps that also use Torx screws. You have to lower the steering column to get to them.
Old Dec 2, 2014 | 06:01 AM
Walleye Hunter's Avatar
Walleye Hunter
Watching closely as I have shifter issues too.
