Sponsored by: Real Truck
How to replace body mounts?
Old May 28, 2008 | 09:12 PM
Mercury45's Avatar
Mercury45
Hi all, I have a 2003 F250 6" all leaf lift with 37" tires
I have had a clunk noise when swinging the truck from left to right or when going over a large bump, but only when wet for some time now and trying to fix it I have replaced the following:
1. Front leaf spring bushings
2. Front leaf springs
3. Sway bar bushings
4. Sway bar drop links
5. Drag link
6. Track bar
7. Track bar bushings
8. Front leaf, rear mounts (affixed to the chassis, this is where the hanger is installed)
Other things i tried...
1. Removed sway bar - no change
2. Tried to lube body mounts (not so easy to do, but no change.)
I have to think it is body mounts, there is nothing left is there?
Anyway how does one replace ALL the body mounts on a truck like mine, is there a guide somewhere?
thanks!
kenny
Old May 28, 2008 | 09:35 PM
dew the thunder's Avatar
dew the thunder
Ball joints?
Old May 28, 2008 | 09:38 PM
Mercury45's Avatar
Mercury45
oh yeah, replaced those too, along with knuckle seals, manual hubs and wheel bearings are fine.
It only does it when wet, so it has to be something stupid
kenny
Old May 28, 2008 | 09:39 PM
Mercury45's Avatar
Mercury45
when the clunk occurs it feels like it is under my floor
kenny
dew the thunder
Tried messing with your shocks? I had some that made a clunk noise when wet once...
Old May 29, 2008 | 01:51 AM
cartmanea's Avatar
cartmanea
Track bar a little loose?
Old May 29, 2008 | 07:34 AM
Mercury45's Avatar
Mercury45
please read the first post... track bar has been done already, its tight
kenny
Old May 29, 2008 | 11:33 AM
juterbock's Avatar
juterbock
Have you lubed the slip joints on your axles?
Old May 29, 2008 | 11:45 AM
Mercury45's Avatar
Mercury45
Oh yeah, i forgot to mention that, You mean the driveshaft right? Anyway YES i lubed them, they were ok before i lubed them but now they are plenty lubed
This happends only when wet by the way
It has to be a body mount or something silly... So now - tonight i will pull the body mount bolts and see what i can find out, wish i had a pry bar
kenny
Old May 29, 2008 | 12:53 PM
juterbock's Avatar
juterbock
Yeah, I'm an idiot, I meant driveshaft.
Old May 29, 2008 | 03:21 PM
Mercury45's Avatar
Mercury45
dont be so hard on yourself, i forget the names of most these parts...
kenny
Old May 31, 2008 | 05:05 PM
XLnAK's Avatar
XLnAK
Sounds like the front cab mounting bolt. Mine is loose as well and makes the same as you discribe clunk. Earlier threads I read here a year or so mentioned the front pass. side cab mount as the leading culprit for this. The head of the front cab mounts is under the carpet and I havent made it under there yet. Hope this helps , sounds like you have a rock Solid front end now. Good hunting.
Old Jun 1, 2008 | 02:06 PM
Mercury45's Avatar
Mercury45
thanks - i am closer to fixing this... i took the garden hose and sprayed everything down one piece at a time, the body mounts were fine, then i tried the rear leaf spring and the noise started, amazing how it sounds like the front when it was in the back!
kenny
Old Jun 1, 2008 | 05:24 PM
XLnAK's Avatar
XLnAK
Wow. A rear spring. I went under mine and found some sign of loose body mount, but with further pushing and pulling found the steering stabilizer mounting eyelet way loose. the bolt holding the shock body to the Axel is tite and shows no sign of movement but the body of the stabalizer floats alot (aprrox. 1/8" up&dwn-16th side to side) might be the clunk I hear most.
Don
Old Jun 2, 2008 | 02:47 PM
HATEnFATE's Avatar
HATEnFATE
I've got a bad mount. Lucky for me I work for a dealership so I can use a hoist and lift my cab off my chassis. If it's an "at home" attempt at these, I wouldn't do it.
MR KROGOTH
45
Apr 28, 2020 10:22 PM
DDDDDMorgan
Oct 4, 2016 01:57 PM
acf6
May 9, 2016 12:42 PM
ss74nova
15
Mar 8, 2016 08:21 AM
