Please help low Boost # after Studs
Old May 28, 2008 | 06:52 PM
zss42002's Avatar
zss42002
Just got ARP studs, liberator egr delete, and fluidampr proffesionally installed. Driving it home i am only seeing 15 psi and 16 going up hill from my dash hawk. Any ideas of why? Also getting a tuner XCAL 2 i will be able to disable the egr sensors? B/C they are throughing a code insuficient exhaust flow and i clear it with my dashhawk.
Old May 28, 2008 | 07:56 PM
rollerstud98's Avatar
rollerstud98
maybe on re-install they have left a hose clamp or something loose and you are losing boost to that?
Old May 28, 2008 | 08:02 PM
denman81's Avatar
denman81
disconnect your batts so your turbo can do a vgt relearn. im guessing with the egr deleted its use to reading the egr and compensating with the turbo. Resetting everything should take care of that. Not a 100% on that but its worth a shot.
Old May 28, 2008 | 08:08 PM
zss42002's Avatar
zss42002
i am gonna dissconnect the batteries right now and see what happens tomorrow. the code it throws is p0401 (exhaust gas recirculation flow insufficient detected)
this is the explanation on it EGR valve position does not match desired, limits based on engine speed/load, egr valve stuck or sticking- egr valve position sensor bias-ep sensor bias.
Old May 28, 2008 | 08:11 PM
denman81's Avatar
denman81
make sure you touch your ends after you get them disconnected so they completly drain the charge.
Old May 28, 2008 | 08:25 PM
FORDSDOWNER's Avatar
FORDSDOWNER
Hey zss, Glad to see you were able to get somewhere with the HGs.
Old May 28, 2008 | 08:29 PM
zss42002's Avatar
zss42002
demman what do you mean touch your ends? both negative battery wires?
Old May 28, 2008 | 09:08 PM
slowmans's Avatar
slowmans
no pos. to neg., with it disconnected you shouldnt have aproblem it will just drain the residual left in the system..
Old May 28, 2008 | 09:25 PM
zss42002's Avatar
zss42002
o i just took off both negatives and left the lights on with the neg discon. i left them off for 10 min. well see tomorrow if the code comes back. In the meantime anyother suggestions??
Old May 29, 2008 | 06:16 AM
zss42002's Avatar
zss42002
no light so far but boost # still low.
Old May 29, 2008 | 06:57 AM
brickie's Avatar
brickie
Does the truck sound normal,is there a strange hiss around the turbo? I was thinking that the up pipe may be leaking at the turbo.If you reach in and cup your hand around the clamp you would feel it if it were leaking,also soot will build quickly in the area if it were leaking there.
Old May 29, 2008 | 02:44 PM
zss42002's Avatar
zss42002
doesn't look like anything is loose. No strange noises either. And currently no codes were thrown so far as of today. but boost got it up to 17 today but still i was getting around 24. could it be becuase of summertime the air quality??
Old Jun 3, 2008 | 07:43 PM
zss42002's Avatar
zss42002
Gonna just get a tuner and disable it nothing is working. Were should i buy a tuner from i want an SCT w/ custom tunes. One to blow coal, an economy, and race tune. I dont know were to get one from i was thinking DP or Spartan. Any suggestions?? Also X 2 or X 3??
Old Jun 3, 2008 | 07:51 PM
doubledee715's Avatar
doubledee715
disable what? the egr? Disabling it isn't going to solve the problem. Go over to go go diesel.com and start a thread and hopefully Doug (PSDPlayer) will chime in and help you out. That's what I would suggest at this point.
Old Jun 3, 2008 | 08:17 PM
zss42002's Avatar
zss42002
disabling the egr will shut off the egr sensors. will it not??
