Sponsored by: Auxito
CV Shaft Noise
Old May 28, 2008 | 05:42 PM
03FX45.4's Avatar
03FX45.4
CV Shaft Noise
My front drivers side CV Shaft is making a horrible squeaking noise while traveling down the road. At first I thought it was the brakes (to give you an idea of the type of sound), but after further investigation I found it was coming from the CV Shaft.
Does anyone know how to cure this problem? New shaft? New boots?
Thanks for any help!
Old May 28, 2008 | 06:21 PM
96f150's Avatar
96f150
Supposedly from what I hear the boots dry up and then you get your noises from that. I have have a noise on my 2001 that happens only when I get below 30 mph. Its a metal against rubber sound. It was definetly not coming from the boot, it was comeing from where the "boot axle splined end" goes into the wheel bearing knuckle. I took off the spindle nut and pushed the axle back inward a bit and saw the seal in there and I cleaned it up and put a light coating of oil on it and now the noise is gone. Does yours do it in reverse?
Rich
Old May 28, 2008 | 07:39 PM
03FX45.4's Avatar
03FX45.4
No, it doesn't do it in reverse. And I think the noise your describing, rubber on metal, is the noise I'm hearing.
Also, when it first started it happened below 30 but now I think it does it most of the time. Only after I have been driving for a bit though, doesn't happen right away.
Old May 28, 2008 | 07:55 PM
96f150's Avatar
96f150
What I did is jack up my drivers side and spun the wheel by hand and I could hear the "noise" so I took soem wd40 with the little hose on it and sprayed a little bit, right where the metal part of the stub axle goes into the knuckle, and the noise went away. It worked for a day, then I did the whole other thing described above and it worked. There is a rubber seal in there, not sure what the hell it does, because this is a sealed bearing, but I think the seal dries out from the heat after a few years and begins to "sing" after a while.
Good Luck
Rich
Old May 28, 2008 | 08:23 PM
03FX45.4's Avatar
03FX45.4
Thanks for the help, I'll try that. Do you know what size the spindle nut is?
Old May 28, 2008 | 08:26 PM
Ultramagdan's Avatar
Ultramagdan
36 mm. Some have reported a different size though.
https://www.ford-trucks.com/forums/7...-nut-size.html
Old May 29, 2008 | 05:42 AM
96f150's Avatar
96f150
I bought a 1 3/8" and it fits like a glove. 36mm and 1 3/8" are very close
Old Jun 6, 2008 | 09:26 PM
03FX45.4's Avatar
03FX45.4
After a little more investigation, I found that the noise is coming from where the axle connects to the differential. Seems like the seal on the differential may be bad I think, so it looks like I'm going to have to take it to Ford and see what the deal is.
Old Jun 7, 2008 | 07:12 AM
96f150's Avatar
96f150
Mine is still going strong with no noises. I would try an eliminate things. Try and spray it with some wd40 or something first and see if the noise goes away.
Rich
AVR2
Escape & Escape Hybrid
Feb 27, 2017 07:54 PM
shad9876
Mar 27, 2010 11:23 PM
CdnSoldier
Canadian National Chapter
Apr 19, 2009 12:05 AM
explorer96
Sep 9, 2004 12:03 PM
