Sponsored by: Auxito
Spindle nut size
Old May 26, 2008 | 05:35 AM
96f150's Avatar
96f150
Spindle nut size
I have read a few different posts and one says 1 3/8" and others say 36mm. What size is the axle nut on a 2001 4x4?
Thanks
Rich
Old May 26, 2008 | 09:25 AM
Ultramagdan's Avatar
Ultramagdan
Mine is a 36 mm.
Old May 26, 2008 | 09:20 PM
bamafordguy97's Avatar
bamafordguy97
If I remeber correctly mine was a 36mm also. I had to replace a CV not to long ago.
Old May 27, 2008 | 01:59 AM
camden2300's Avatar
camden2300
I just replaced ball joints on my 98 f150 off road and can tell you I bought and used the 36 mm after reading it was the correct socket. However it was a sloppy fit so i can def. tell you 36mm is probably not the correct size for your truck either. I dont know what your planning to do but if you live where there is salt on the road in the winter make sure to get yourself a good 3 jaw puller and sledge to get the axle to start sliding out.....My axle was frozen in the hub and took over six hours of pb blaster, pullers, and beatings to dislodge it
Old May 27, 2008 | 03:20 PM
96f150's Avatar
96f150
Well, I took a chance and got the 1 3/8" and it fits like a glove. Bought it for $10 at Autozone. Nice 3/4" drive too.
Thanks
Rich
Old Apr 15, 2010 | 10:09 PM
ozz115's Avatar
ozz115
i have a 97 f150 4.6 cant find the right size socket for the spindle so would mine be 1 3/8 also 5 bolt hub tried a 34mm ' 1 9/16 1 5/16 all to small can any 1 help me thank you
Old Apr 16, 2010 | 03:50 AM
NKENN's Avatar
NKENN
Thanks
Rich
1-3/8" equals 34.925mm.
Old Apr 18, 2010 | 01:40 PM
ozz115's Avatar
ozz115
found out it is 1 3/8" for my 97 f150
Old Dec 10, 2016 | 12:20 PM
Michael Nebehay's Avatar
Michael Nebehay
I have a '01 F-150 lariat. Trying to change the hub. I was told I needed a 36mm, but that's too small. 1⅜" is a little smaller, so maybe 1½"?
Old Dec 11, 2016 | 01:20 AM
shooter123's Avatar
shooter123
I did lower ball joints on my 1997 f150 4x4 today, I used a 35 mm socket on the axle nut.
Old Feb 19, 2017 | 10:15 AM
Lacey Bundschuh's Avatar
Lacey Bundschuh
2003 Ford F-150 fx4 lariat off road
Ours is a 35mm axel nut socket. It doesn't come in an axel nut removal kit it must be purchased separately as the kit only has even numbers.
QUOTE=96f150;6194014]I have read a few different posts and one says 1 3/8" and others say 36mm. What size is the axle nut on a 2001 4x4?
Thanks
Rich[/QUOTE]
Old Feb 19, 2017 | 06:27 PM
tcrote5516's Avatar
tcrote5516
I couldn't find a 35mm when I needed it so I grabbed a 36mm. The 36mm will work but as others have said it's sloppy and not ideal when you consider how much tq you need to apply to break it free.
Old Feb 20, 2017 | 09:12 AM
Lacey Bundschuh
36 wouldn't work for us, we went to advanced auto and purchased the 35mm socket which is in stock in the "tools" section in the aisle, not with the "sockets" up front. Even the lady at the counter didn't know that lol. I'm not sure where your from, but the other places that carry it are Home Depot, lowes, sears/Kmart, napa auto, auto zone, and pep boys. Using the wrong size socket can warp your tools and the axle nut itself.
Old Feb 21, 2017 | 03:11 AM
FordTruckChuck's Avatar
FordTruckChuck
Auto Zone & Advanced Auto loan out those big sockets & pullers along with alot of other tools. I always check with them when i need a tool not often used. You just have to leave a deposit then get it all back when you return it.
Old Mar 31, 2021 | 11:27 PM
Dennis Lange's Avatar
Dennis Lange
Axle nut size
35mm is what you want .
