7.3l Specs
Old May 31, 2008 | 11:45 AM
  #31
ernesteugene's Avatar
ernesteugene
Originally Posted by cmpd1781
Anyway, here goes...... ***Caterpillar DOES make the 7.2L C7.....Haven't checked the dimensions on that one yet (it's 400 or 500 lb heavier), but the performance specs aren't that different......
Again...This is only INITIAL brainstorming....... Cheers, and flame-away!
Here's some specs on the C7 which is what I've got now, having recently traded my early 99 SRW F350 for a Freightliner "monster truck" to pull my new 40' triple axle 5er.
I've seen several F650's with the C7 while visiting CAT shops, and even there it looks to be a fairly cramped engine compartment compared to my Freightliner. I think the height of the C7 is the biggest issue, and you'd need to build a special hood, and then raise the drivers seat to see over that, depending on how tall you are.
If you want specific dimensions on anything just let me know, as I can literally walk around inside my engine compartment and measure to about a 1/4" accuracy!
C7 Specifications
Cylinders In-Line 6
Bore/Stroke 4.33 x 5.00 (110mm x 127mm)
Displacement 7.2 L (441 cu in)
Weight 1295 lb (588 kg)
Horsepower 300 to 350 @ 2400 rpm
Torque 860 lb-ft @ 1440 rpm
Tedster9
23
Apr 20, 2016 11:14 AM
AZAV8
36
Jun 14, 2015 03:03 PM
Ranger Bob
2004 - 2008 F150
Jul 29, 2014 07:47 AM
luthoro
May 25, 2012 03:26 PM
isaacwd
Mar 20, 2004 10:50 PM
