7.3l Specs
Old May 29, 2008 | 10:12 AM
F350-6's Avatar
F350-6
So cmpd1781, what have you done that you're in need of a new motor?
If you're looking for something different you can drop a Cummins in there. We've got a couple of folks doing that now.
Old May 29, 2008 | 10:22 AM
That_Guy's Avatar
That_Guy
I think the DT466 will fit in there without to many modifcations...that might be another option
Old May 29, 2008 | 10:30 AM
parkland's Avatar
parkland
Ohh noo, here I ramble on again.
MaxxForce™ DT for Class 6–7 Trucks - MaxxForce™
Put this sucker in there. I might fit without a fan or rad, which would need to go in the box i'm thinkin.
7.6 liters of inline 6 that could employ the 5.9 cummins as a starter.
Plus, its international, so you could get some sexy stickers for the truck.
You'll never ever put the c series cat in there.
Youre options are cummins 5.9 with little effort, 466 with some modding, c15 with the engine on a trailer.
Old May 29, 2008 | 01:36 PM
cmpd1781's Avatar
cmpd1781
Originally Posted by miller_feed
There would be value to this, and lots of it.
You mean 'cost', don't you?....
Old May 29, 2008 | 01:44 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Exactly what I mean. But don't get me wrong, I would love to watch this proceed. With plenty of pics.
Old May 29, 2008 | 01:45 PM
cmpd1781's Avatar
cmpd1781
Nothing wrong at all.......
It's still a little under 100000 miles and running great.
I'm just considering a couple of things. For one thing, I'm not really interested in the new city trucks.......They're too 'dolled' up, the exhaust systems suk big time, and they get crap mileage.......
So I'm either going to stay with my model truck (1999-2003) and end up (when the time comes) getting another 7.3L, or putting a 'work' engine inside.........
I also wanted something that had all the hp and tq I needed WITHOUT having to 'mod' the engine.....(Don't you guys run into problems after you 'mod', or 'chip' the trucks?.....).
I just had an idea kick loose when I saw the C15 in the mag the other day, and started the 'why-not' questions---then jumped over here to the forum to see if (certain) 'other' engines would even fit into the engine bay---and what it would take to make something like a Caterpillar C9 or a C7 (the others are just obviously too big to make it) work in a superduty 250 or 350.......
Just looking to the future.
Hell. I haven't even 'modded' the one I've got.
Old May 29, 2008 | 01:48 PM
cmpd1781's Avatar
cmpd1781
That much (C15) I figured out on my own......
Maybe I could get it to work in a rebuilt 1944 King Tiger tank......
Old May 29, 2008 | 02:03 PM
F350-6's Avatar
F350-6
Me either, but if you haven't even hit 100k yet then I'd say it's too soon to start planning a swap that may be obsolete by the time you need it. I've got around 253k on mine and I'm no where near the top of the list for high miles.
But several of those guys above me do have modded engines.
Old May 29, 2008 | 02:11 PM
orng1's Avatar
orng1
I have a friend that is running a 353 in an old dodge, we've been tryinbg to find another one for a friends old chevy truck.
Old May 29, 2008 | 02:55 PM
monsterbaby's Avatar
monsterbaby
Personally I wouldn't look so much at the cat engines, by the time you find one small enough to physically fit it's basically back at the same or less hp then the 7.3 or the 5.9 cummins unless you mod it which defeats the entire purpose your trying for. My personal recommendation would be either like you said buy a crate motor and replace yours or do the swap to the cummins since it has a great reputation, decent power moded or not, has a lot of aftermarket support just like the PSD and since it's already been done in the past you KNOW it will work and you can buy most of the parts you need to do it.
But like someone else pointed out if you don't have problems you know of yet 100k is a whole lot early to worry about replacing it yet, it's not like a gasser that 100k is when you start worrying about it. Think of it this way, typical gasser had a 36,000 mile warrenty and you typically didn't worry to much about them for 3 times that amount until they had over 100k so the PSD has a 100,000 mile warranty so figure same basis of approx 3 times the warranty your looking at 300,000 before you should be concerned (and believe it or not thats actually about right)
As to modding them. Heck I have mine with kwik filter 5" straight pipe exhaust, regulated return fuel system and a DP Tuner with 40, 60 80 120 and 140hp tunes and I race it regularly at the local 1/8th mile tracks and currently has 132K on the clock with no problems beyond standard maintnance (hoses, belt, water pump, Alt, and starter)
Old May 30, 2008 | 01:28 PM
cmpd1781's Avatar
cmpd1781
I'm just dreading the day when the injectors need replacing. I heard THEM suckers eat a couple of grand out of your wallet.......
I know, I know.....The 7.3L can go ya 300, or 400, or 500-thou before crapping out. That's one thing I like about them.....
Hey....At least I'm finally going the syn route....(Royal Purple).....That's all I'm using from now on........
Old May 30, 2008 | 01:40 PM
miller_feed
I seem to be different. I can't wait for the day I change my injectors and turbo. And there is nothing wrong with mine.
Old May 30, 2008 | 05:19 PM
  #28
That_Guy's Avatar
That_Guy
Sure there is, the turbo doesnt flow enough air and the sticks dont provide enough fuel to the engine
Old May 30, 2008 | 07:01 PM
  #29
Planeoldguy's Avatar
Planeoldguy
This has been swapped in by a few people.
International : DT 466
Old May 31, 2008 | 07:56 AM
  #30
cmpd1781's Avatar
cmpd1781
Why not? We've been putting their CPSs in for years for replacements...!...
Weight-wise, it's not too different from the CATs.....(about 500lb heavier than the 7.3L)
I like the torque numbers, and there's just something about the inline-6......
